Removing water spots from windows
Discussion in 'Detailing' started by Babybluetaco, Apr 2, 2019.
  1. Feb 7, 2023 at 11:38 AM
    #41
    johnpick160
    johnpick160 New Member
    2019 White TRD OR DCSB
    I’ve had pretty good luck with Sud Factory products. Their water spot remover on a foam polishing pad on a drill or buffer takes water spots right off of glass. Follow up with Invisible Glass on a clean microfiber towel and it’s as good as new.
    Bikerscum likes this.
  2. Feb 7, 2023 at 7:46 PM
    #42
    pinktaco808
    pinktaco808 Hot Steppa
    Diamond glass cleaner
  3. Feb 11, 2023 at 10:47 AM
    #43
    Bikerscum
    Bikerscum Well-Known Member
    2023 TRD Prem. OR 4 dr. short bed, Adv. Tech, LED headlights, Mag grey
    +1 on Sud Factory water spot remover. I thought my acid rain etched windows were hopeless, now they look like new.
    pinktaco808 likes this.
  4. Mar 25, 2023 at 10:05 PM
    #44
    hucares
    hucares Active Member
    Howard
    2022 TRD OR
    I use a product called Ring B Gone. It’s advertised as a toilet bowl cleaner for hard water. Ive used it on plastic, stainless steel and glass. It works great on the calcium buildup.
    As always, test on a hidden area first and use gloves.
  5. Apr 12, 2023 at 1:49 PM
    #45
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have a commercial grade wire wheel cleaner that when sprayed onto a micro fiber cloth removes all stains. I have used suds factory water spot remover and the wire wheel cleaner was faster and did a better job in only a few minutes. I learned the tip many years ago but did try sud factory which is a decent product. I may use it if I don't have any wire wheel cleaner. I have been in the detail business for over 36 years mostly part time and now full time but I do only one vehicle a week. I still get commercial products from the same company and I swear they are better than anything else I have tried over the years.
    FishnTx likes this.
  6. Apr 13, 2023 at 4:36 AM
    #46
    Bikerscum
    Brand?
    Thanx
  7. Apr 13, 2023 at 9:49 AM
    #47
    VaToy
    Parts Unknown
    Comondore coatings in Richmond Va.
  8. Apr 13, 2023 at 7:07 PM
    #48
    Bikerscum
    I don't see a wire wheel cleaner there... just a general wheel cleaner
  9. Apr 13, 2023 at 9:02 PM
    #49
    VaToy
    Parts Unknown
    Idk, maybe call them. I'm sure any wire wheel cleaner will work when sprayed onto a rag and rubbed onto the glass.
  10. May 23, 2023 at 8:16 AM
    #50
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    There are water spot removal sprays but white vinegar, water, and baking soda work well along with a clay bar if you need the added boost.
  11. May 23, 2023 at 8:18 AM
    #51
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    this is what i use for my water spots that nothing else would remove. works great.
  12. May 23, 2023 at 8:19 AM
    #52
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    that doesn't work for whatever is causing my spots. tried this several times.
  13. May 23, 2023 at 8:48 AM
    #53
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Leave it be for a while
    It comes off on its own
  14. May 29, 2023 at 5:12 PM
    #54
    Apollo14
    Apollo14 EEF Brand Ambassador
    Jonathan
    Vail, CO
    2018 Cement Taco TRDOR DCSB
    Razor blade with invisiglass.
    it’s like claybarring your windows.
  15. May 22, 2024 at 7:04 PM
    #55
    Wes36
    Wes36 Member
    23 tacoma trd offroad
    How did you clean them with this stuff ?? Ty
