Removing Wheel Weights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GuitarfreakD, Jul 16, 2011.
  1. Jul 16, 2011 at 7:57 AM
    GuitarfreakD
    GuitarfreakD [OP] Active Member
    Memphis, TN
    10 4X4 TRD Access Cab
    Is it necessary to remove the weights when you paint your wheels, or can I just prep the whole wheel and cover the tire and then paint?
  2. Jul 16, 2011 at 8:05 AM
    GuitarfreakD
    Memphis, TN
    I am also having trouble finding a post of DYI on exactly how to do the wheels. Does anyone have the link with pictures?
  3. Jul 16, 2011 at 8:15 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Think about it, paint wheels with weights in place, then later get a tire balance, and guess what, non painted areas!
    Look for the many posts on painting the stock wheels, many guys carefully remove and mark the position of the weights, paint both wheels and weights then replace weights in the original spots. Or, I just had the guys balance from the inside of the wheels on my last tire rotation/balance, which would be better for you so you would not mare your newly painted finish on the outside of the rims. :cool:
