Removing Wheelers 3 AAL, returning to stock?
Discussion in 'Suspension' started by gunhound, Apr 28, 2013.
  1. Apr 28, 2013 at 9:35 AM
    gunhound
    gunhound [OP] Gunhound
    CO
    2013 DCLB Sport
    5/15 tint, NFab step bars, Viper SST, Weathertech floor liners, Toyo A/T IIs on 17x9 XD Menace wheels. Lift - SPC LR UCAs, Wheelers 3 pc AAL, OME N140s, N182 and 885 w/ TP spacers.
    Need to remove a Wheelers progressive 3 AAL so I can return it to stock configuration.
    This is on a 2012 DCLB Sport 4x4.
    Since I cut the factory brackets, would I need to come up with some type of after market brackets?
    Thanks
  2. Apr 28, 2013 at 9:37 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yes, you should put something back to keep the leafs in line. I can be as simple as 2 pieces of plate steel and 2 bolts. Check out what 4WD (Doug) does for leaf spring retainers on the leaf packs he builds.
