Removing wire connectors under passenger seat?
Discussion in 'Audio & Video' started by kaitlyn2004, Sep 27, 2020.
  1. Sep 27, 2020 at 12:19 PM
    kaitlyn2004
    kaitlyn2004 [OP] New Member
    NOTE: I have a 2020 4Runner, but wanted to also ask here as I assume things are very similar, and you guys may also know about removing these connectors :)
    I'm working on installing the OEM Audio Plus amplifier under the passenger seat. I took this photo:
    https://imgur.com/DR03Ij7
    Removing the yellow + white connector was easy enough, but I cannot for the life of my get the grey one off (why must they all use different style connections!?)
    Some of the install stuff I've seen also mention REMOVING the white connector piece from the metal frame, which would absolutely make my next step of tightening a nut a lot easier... but I also cannot seem to remove this piece? It wiggles but any type of pulling does not want to peel it off... obviously don't want to force anything and break something because I'm not even sure how it's secured.
    Any help with these pieces?
  2. Sep 27, 2020 at 1:37 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    There are little tabs on the top side that click into place. You need a 90-degree pick tool or something to get to that tab to press it in, then the connector slides off.
    for that grey connector, it unplugs exactly how you think it does. They’re just a really tight fit.
  3. Sep 27, 2020 at 1:39 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Also, be sure to leave the batter disconnected until the yellow connectors are plugged back in. Those are airbag wires and it will trigger all sorts of warnings in the computer system that the dealer will usually have to clear (which they won’t do without inspecting the connectors, which they charge handsomely to do)
  4. Sep 27, 2020 at 3:38 PM
    JimResnikoff
    JimResnikoff Well-Known Member
    JIm
    Tacoma
    Rockford / Focal Audio upgrade
    @destin_meeks Mine threw a code when I forgot to plug one of the clips in.. Fortunately is cleared once I plugged it back in.
  5. Sep 28, 2020 at 8:55 AM
    kaitlyn2004
    I ended up being able to tighten the nut I was trying to access without removing the connectors... so I basically made it no further than before. I give up on removing them - at least I was able to do what I needed with them still there (It wasn't easy though!)
