Repainting fender flare
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chigatterun, Jun 30, 2015.
  1. Jun 30, 2015 at 12:46 PM
    Chigatterun
    Chigatterun [OP] New Member
    2015 tacoma trd
    Hey guys, i was thinking of repainting the rear fender flare on my tacoma cause it got scraped up against a bollard. Its a stock trd flare and i was wondering if sanding it down and then painting it with the dupli color primer paint and clear coat would work well. I assume its made out of plastic? does duplicolor works well on that surface? Thanks!
  2. Jun 30, 2015 at 12:54 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Make sure the primer states that is for use on plastic. Usually you have to use a special plastic primer because, to answer your question, yes, the flare is made of plastic and regular primer or paint will not adhere well.
