Repair clutch trouble
Discussion in 'Toyota Trucks & SUVs' started by plomo24, Jun 5, 2010.
  1. Jun 5, 2010 at 1:41 PM
    plomo24
    plomo24 [OP] New Member
    Austin
    94 T-100 standard V6
    How difficult is taking bolts off clutch shroud on '94 T-100?
  2. Jun 5, 2010 at 2:00 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Clutch shroud? Do you mean the bell housing? If so, the tranny has to come out.
  3. Jun 5, 2010 at 7:26 PM
    plomo24
    Austin
    yep, did mean bell housing, which... when I take off the bolts (good luck)
    the transmission comes off at the same time. I've got the drive shaft (double) off. I'm
    I'm sure I will have to take of the stabalizer bar so the tranny can be lowered.
    I freed the gear shift of the cover boot. The gear shift lever stays on the
    transmission, I suppose. I will have to take off the stabilizer bar since, it will be in the
    way when I lower the transmission. (I had to clean up the dirty and greasy
    transmission parts and surrounding areas ...what a mess, but better now) But, the bolts
    are extremely difficult to take off. Is an impact wrench and compressor absolutely
    necessary tools to have for this? I put some some liquid wrench and will wait to see if
    that helps to loosen them some. But there is one bolt at the very top that is going to be
    very tricky to get to.
  4. Jun 5, 2010 at 7:28 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Huh, I've never done the clutch on a toyota before so I couldn't tell you how difficult the bolts are to get off. I would just get a big breaker bar and a 6 point socket to break them loose. Or an impact wrench.
