Repair composit Bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimott, Oct 9, 2019.
  1. Oct 9, 2019 at 2:19 PM
    Jimott
    Jimott [OP] New Member
    I bought a damaged 2019 Tacoma.The bed is cracked clear across. It is off the body so I can see both sides. It is cracked right above one of the webs but does not extend clear through.
    From looking at a number of rear ended Tacomas I can see it is common n many rear end collisions. Does anyone know if there is a "kit" to reinforce the area. Or had any experience in repairing it themself.
    Thanks
    Jim
    Hobbs likes this.
  2. Oct 9, 2019 at 2:24 PM
    ian rogers
    ian rogers Well-Known Member
    Ian
    Sf Bay Area
    69 fj40, 2019 OR manual
    Locked Sliders Roll cage H41
    It’s fiberglass right? Should be able to fix it with some 4 inch tape and epoxy. Do you have any boatyards near you? They can do this work.
    Big tall dave likes this.
  3. Oct 9, 2019 at 2:28 PM
    Shellshock
    Iowa
    I’d replace it with a ute tray from Norweld or patriot
  4. Oct 9, 2019 at 2:28 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum! And good luck!
    Bed repair
    Bed repair or replacement?????
  5. Oct 9, 2019 at 2:30 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Would it make sense to drill and screw a bunch of 1" inch wide 1/4" or 3/16" thick flat steel bar to the bottom of the bed, under the channels, across the crack like a series of "stitches", and just live with the crack? I would think as long as you did a lot of them, and they were long with several screws per bar nicely spaced with big enough washers to keep the load nice and distributed it would be a solid, quick, and very cheap repair. Wouldn't look pretty though as you'd have a lot of screw heads visible in the bed but something tells me you don't need this truck to be pretty, just functional.
    I just realized this wouldn't work because all the webbing underneath. Could work on the top though but it would be even uglier.
  6. Oct 9, 2019 at 2:31 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Other than cost, I like this idea.
    Junkhead and JS760 like this.
  7. Oct 9, 2019 at 2:58 PM
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    Short answer is no.
    Get a take off and swap the sheet metal or replace it with a new one or go with a utility like previously suggested.
    Junkhead likes this.
  8. Oct 9, 2019 at 7:02 PM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    I do composite repairs (Carbon Fiber, Kevlar, Fiber Glass) on Military Aircraft and it's possible to repair it, however it does require certain equipment and materials to accomplish the repair. Most repairs require a heat blanket with thermos couplers and specific temperatures during the curing process while being enclosed in a vacuum bag for a specific time.
  9. Oct 10, 2019 at 2:03 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    If the beds are fibreglass, couldn’t the OP just fix it like a normal fibreglass boat repair? I realize the temperatures have to be within a certain range but would he really need vacuum bags and thermo couplers? I’ve experimented with carbon fibre making motorcycle fairings and I can see the necessity of vacuum bags for molds but....Truck bed repairs?
    With fibreglass repairs i’ve always just drilled small holes at the end of each crack, ‘V’ ground the cracks with a Dremel and then epoxyed it. If it’s major damage or if i want more strength i’d use some fibreglass matting too.
    Coyote501 likes this.
  10. Oct 10, 2019 at 2:10 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It’s not just fiberglass, it’s got other material in there too. Definitely some Fiberglass though because it’ll make you itch if you’re not careful when drilling into it.
    Big tall dave[QUOTED] likes this.
  11. Oct 10, 2019 at 5:25 PM
    Halena Molokai
    You are correct in that you can repair it anyway one can with what's available and if it works for you or that person all good. Vacuum bags are not for just moldings but a requirement for the strength of the repair when it comes to composites. By vacuuming the repair you extract all the excess resins and compress the fibers to give it it's strength. When laying multiple layers of carbon fiber you just don't lay one layer over the other of equal size but in different sizes with each layer overlapping it with a bigger patch. Each layer is then positioned with the fiber angled in different degrees (45-0-+45-0) depending on the layers required. $.02
  12. Oct 10, 2019 at 7:19 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  13. Oct 10, 2019 at 8:10 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
