Repair shops
Discussion in 'Hawaii' started by happyb, May 25, 2011.
  1. May 25, 2011 at 9:53 AM
    happyb
    happyb [OP] Well-Known Member
    Brandon
    on a beach in hawaii
    to my taste
    making a list
    just the other day my truck started to squeak really bad. the worse was when i am in reverse but it also squeaks going slow going forward. it seems to me like it's the brakes, but i'm no mechanic. can anyone recommend a good shop to get work done at? mahalos.
  2. May 25, 2011 at 2:28 PM
    TRDGRL
    TRDGRL My Toys.....
    TRDGRL
    RainForestVille, Honolulu, Hawaii
    '11 BLK Tacoma PreRunner TRD SR5 Access Cab
    See Signature.....
    Take it to the dealer if its under warranty......:rolleyes:
  3. May 25, 2011 at 3:10 PM
    happyb
    Brandon
    to my taste
    making a list
    don't got warranty anymore
  4. May 26, 2011 at 3:32 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    squeaks...like only when you step on the brakes? or all the time? is it noticeably worse over bumps or consistent?
    when's the last time you replaced the brakes? fronts should be around every 30k ish (+ or- depending on how you drive), rears around 60K ish
    i know the drum brakes in the back tend to squeal at times, especially if they are left wet (if you wash your truck n don't drive it for awhile after)
    can you isolate where the noise itself is coming from? like front or rear?
  5. May 26, 2011 at 4:07 PM
    happyb
    Brandon
    to my taste
    making a list
    it's not all the time, but usually when i'm at low speeds coming to a stop and reversing. i get the squeaking noise when i turn my truck at low speeds. seems like i gotta check my lower ball joints and steering.
    i just hit a little over 60k miles, so i know it's time to do my brakes. i'm surprised my brakes have been pretty good for this long.
    the shitty thing is the noise is front and back. i feel pretty embarassed to drive my truck during traffic cause it makes soo much noise. i plan to get it checked out next week since i can use my mom's car while she's away for work.
  6. May 27, 2011 at 2:45 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    yeah make sure they check the tie rod bushings and the ball joints. sounds like the back might be the leafs. your lifted right? AAL?
  7. May 27, 2011 at 2:48 AM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    My brakes have 125k on them and my shop told me I have plenty of pad left
  8. May 31, 2011 at 4:53 AM
    ShaydenandDiezel
    ShaydenandDiezel Well-Known Member
    Hawaii
    TRD
    6 inch Pro Comp Suspension Lift. K&N intake. Air Raid throttle body spacer. 20 inch XD Diesel rims. 33x13.50 Irok tires. Single in dual out exhaust with SS tips.
    Could just be brake dust or maybe a rock stuck in one of the pads. If it's a rock it is usually pretty loud squeaking. It also gives the effect as if it is more then one rotor squeaking. If your lifted and you have over size tires or just wider tires or rims, check your front wheel bearings. Good luck.
  9. May 31, 2011 at 1:34 PM
    happyb
    Brandon
    to my taste
    making a list
    wheel i just put on new rims/tires so i have to get an alignment done. i'll just ask wherever i go to check it out.
