Repaired Air Conditioner, Can't Get Refrigerant To Enter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WAGONWHEEL, May 17, 2020.
  1. May 17, 2020 at 3:26 PM
    WAGONWHEEL
    WAGONWHEEL [OP] Active Member
    Dallas/Ft Worth, Texas
    2012 PreRunner, SR5
    None
    My air conditioner was working fine. Then it slowly started to become less cool. I inspected and found a leak at the compressor high pressure line. I replace the crush-washer/seal on the high and low pressure lines. I connected my gauges, pulled a vacuum (it held), vacuumed the system for over an hour, connected the new can of refrigerant, started the engine with AC on and opened the low pressure side valve. Nothing happens. I did some trouble shooting and am sure refrigerant can make it through the gauge set. The compressor never engages to start sucking it in. I checked the AC fuses (two under the hood) and their good. I am a mechanic (but don't service AC too often). I did watch the ChrisFix video and am pretty much following his directions. Any ideas?
  2. May 17, 2020 at 3:28 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Are you using a real manifold gauge set?
  3. May 17, 2020 at 3:51 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    It’s been an eternity since I worked on AC but... Don’t you have to jump the low pressure cutoff switch to get the compressor to kick on?
    Crazydave and tacofish like this.
  4. May 17, 2020 at 3:59 PM
    ogg
    ogg Well-Known Member
    Eric
    Ohio
    2015 TRD OR
    Supercharged with 2.85 pulley King ext travel with resi's Total Chaos Uppers All Pro Expo leafs Fox 2.0 with resi's rear Level 8 wheels 285/75r16 Mickey Thompson ATZ Prinsu rack SOS sliders, front and rear bumpers, skids
    I had the same thought. It's been a long time since I've had to do any a/c work but almost certain I had to jump that switch to get the compressor to kick on .
  5. May 17, 2020 at 5:12 PM
    WAGONWHEEL
    2012 PreRunner, SR5
    None
    Thank you for the replies.
    • Yes, I am using a real set of gauges for R134A (red hose, blue hose, yellow hose, etc)
    • I had not thought of jumping the low pressure switch, I though it would trip as soon as some of the refrigerant from the pressurized can entered the system, I will give that a try next chance I get (hopefully tomorrow).
    vssman likes this.
  6. May 17, 2020 at 5:54 PM
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    You shouldn't have to run the a/c. It won't run anyways due to the hi pressure switch seeing no pressure. The vacuumed down system and pressure of the a/c refrigerant supply source should charge the system. When the pressure switches see enough psi the compessor will engage.
    Only the old R12 systems I delt with required the compressor running to draw freon in.
  7. May 17, 2020 at 6:01 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I dont have much experience with the cans because we have a big 'ol machine at work.. but there should be enough pressure in the can to push some in there and get the compressor going. Are you sure the can is opened and connected correctly?
    Scott W likes this.
  8. May 17, 2020 at 6:18 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    OP you have the truck running with the ac on max? And you are filling from the low side correct. FYI the compressor should be running.
  9. May 17, 2020 at 7:23 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Are you using the correct can tap? The newer self sealing cans require a self sealing can tap with a flat tip. If you use the incorrect can tap refrigerant won’t come out.
    When I filled my system starting from empty it took about 5 minutes of filling until the compressor kicked on. The low side was about 15 psi when the compressor kicked in.
  10. May 17, 2020 at 7:28 PM
    WAGONWHEEL
    2012 PreRunner, SR5
    None
    • I too would have thought the vacuumed system and the pressure from the can would push enough refrigerate into the system to trip the switch and start the compressor.
    • I do have the truck running with the AC turned on, the fan speed is not on high, but the AC is on and on recirculate. I am filling (or trying to) from the low side.
  11. May 17, 2020 at 9:11 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lets see a picture of your setup. The charge can is on the middle hose correct?
  12. May 18, 2020 at 3:12 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    This is the correct answer above. I experienced this yesterday when I installed a new condenser. By fiddling with the can tap I finally got it to work. Look at your can tap. Pointed or flat piercing?
  13. May 18, 2020 at 5:24 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    I just had the same thing with my corvette. The compressor must be engaged to accept a charge...………….
  14. May 18, 2020 at 6:15 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    This is exactly what should happen once enough refrigerant has entered the system the compressor should kick in.
  15. May 19, 2020 at 4:36 AM
    DBiffle
    DBiffle Member
    The valve on the line is not intuitive, the valve turns right goes down and opens the seal.
  16. May 19, 2020 at 5:07 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    It'll take a can, or close to it before the compressor kicks on when recharging. Mine did when I replaced the expansion valve.
  17. May 20, 2020 at 4:05 AM
    WAGONWHEEL
    2012 PreRunner, SR5
    None
    The cans of refrigerant I have are the self sealing type. It looks like that is all you can get these days. The can tap I have is old and is for the old, non-self sealing type of can. It looks as though that is why I cannot get the refrigerant out of the can. Although, a little bit will come out when the tap is it the correct spot. I will get a self sealing can tap and try again this weekend and post an update. I do appreciate the help I have gotten from the forum. You guys are very helpful--thank you.
    gasgasman, vssman and gotoman1969 like this.
