Repeating Clinking while Turning and Sliding on a Snowy Road in 4WD High
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CaptainBDSC, Feb 20, 2025.
  1. Feb 20, 2025 at 7:30 PM
    CaptainBDSC
    CaptainBDSC [OP] Active Member
    Brent
    Utah
    2013 grey V6 4x4 Double Cab Long Bed (115k miles)
    Stock
    This winter, in my 2013 4D long bed base, I have noticed twice now if I am in H4 on a Snowy road and turn left slide/lose traction I will hear repetitive clinking sound... What the heck is that?
    215k miles - have followed maintenance schedule
  2. Feb 21, 2025 at 7:09 AM
    Citron
    Citron Well-Known Member
    Oklahoma
    2012 Tacoma TRD Sport
    Sound from the front? Happens during turns? I would check cv axle.
  3. Feb 21, 2025 at 9:12 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    This ^x2.
    Cv axel.
  4. Feb 21, 2025 at 7:02 PM
    CaptainBDSC
    Brent
    Utah
    Stock
    It does sound like the sound is coming from the front.
  5. Feb 21, 2025 at 9:26 PM
    CaptainBDSC
    Brent
    Utah
    Stock
    I only hear this sound when in 4WD and I am turning and I am sliding. It almost sounds like anti-lock braking but more loud and I don't really remember feeling it in on the brake pedal.
    Traction control is on.
  6. Feb 22, 2025 at 5:53 AM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    your vsc/ traction control/abs is just doing it's thing... completly normal.
  7. Feb 22, 2025 at 7:58 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    That's likely your traction control trying to straighten you back out.
    If you're not familiar with it, it can be a bit of a surprise.
    CaptainBDSC[OP] likes this.
  8. Feb 22, 2025 at 10:17 AM
    CaptainBDSC
    Brent
    Utah
    Stock
    Thank you!
    OffroadToy[QUOTED] likes this.
  9. Feb 22, 2025 at 10:17 AM
    CaptainBDSC
    Brent
    Utah
    Stock
    Thank you!
    winkel[QUOTED] likes this.
  10. Feb 23, 2025 at 10:52 AM
    Flex-AZ
    Flex-AZ Well-Known Member
    Flagstaff, AZ
    2015 TRD Sport DCLB
    Camburg/Deaver mid travel
    I have had the rude awakening of the VSC system engaging and scaring the crap out of me too. There is a button left of the steering wheel to disengage the VSC system. Pressing this once will allow to disengage but only below 30 mph. Above that speed, it overrides the button and VSC is active again. To truly disengage the system, hold that button down for longer than 3 seconds while in Park. You will see the TRAC OFF light come on to verify that it’s truly disengaged. This has been a game changer for me. Good luck.
  11. Feb 23, 2025 at 3:29 PM
    CaptainBDSC
    Brent
    Utah
    Stock
    That is really good to know! Thank you!
  12. Feb 23, 2025 at 4:29 PM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    First time I had the auto braking feature I thought I damn ruined something in my truck!
    Still, if its only happening when you turn left, Id definitely check/be worried about the front cv, especially since you notice it only in 4wd. Im suspecting you've still left the truck in 4wd when you get to your destination and make hard turns parking or pulling into a location thats hard pavement.
  13. Feb 23, 2025 at 4:36 PM
    CaptainBDSC
    Brent
    Utah
    Stock
    I guess I will have to try turning right and attempting to slide/lose traction.
    I did leave it in 4WD for the remainder of the trip which was entirely on pavement, but icy snowy pavement.
    I do have my annual emissions/fog test next coming up, so I just may ask them to take a look at that...
  14. Feb 24, 2025 at 10:17 AM
    OffroadToy
    Also, should kick in when losing traction going straight down a steep snow/ice covered incline while braking.:mudding:
  15. Feb 24, 2025 at 3:34 PM
    JohnnyGraphic
    JohnnyGraphic Well-Known Member
    Johnny
    Northern California
    2021 4Runner TRD OffRoad Premium
    Falken Wildpeak AT3Ws
    To rule out the CV axle issue, crawl under the front of the truck and take a look at the rubber boots. Look for signs of grease leaking out or greasy build-up on the boots/axles.
    And, I'm not 100% sure I would trust an emissions testing place to diagnose a suspension or driveline issue. Not sure about Utah, but in CA, they're just emissions testers, not a mechanic in any way.
  16. Feb 24, 2025 at 9:51 PM
    CaptainBDSC
    Brent
    Utah
    Stock
    It won't be just an emissions place. I'll be paying the premium dealer rate for emissions, 115k mi maintenance, and see what they can see without digging too deep. I have a pro mechanic in my family that would do any major repairs if indeed they find anything and he confirms their diagnosis.
  17. Feb 24, 2025 at 10:25 PM
    JohnnyGraphic
    Johnny
    Northern California
    Awesome!
    Hope whatever they find is a non-issue or easily/cheaply fixed. ;)
