Replace 10yo fuel pump while the tank is out?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jid1234567, Feb 17, 2015.
  1. Feb 17, 2015 at 11:59 AM
    jid1234567
    jid1234567 [OP] Member
    Jen
    New York
    02 xtracab 4x4
    I'm replacing the fuel tank on my '02 truck. The fuel pump still works, but I'm wondering if I should replace it while the fuel system is in pieces.
    Any advice on lifespan of tacoma fuel pumps?
  2. Feb 17, 2015 at 12:03 PM
    jid1234567
    Jen
    New York
    02 xtracab 4x4
    The truck has 53,000 miles on it. Forgot to mention.
  3. Feb 17, 2015 at 12:11 PM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    Mine just started acting up at 230,000. I would reuse it if it's fine but its your money. Won't hurt that's for sure
  4. Feb 18, 2015 at 2:15 PM
    jid1234567
    Jen
    New York
    02 xtracab 4x4
    Thanks.
    Another maybe relevant detail is that I'm replacing the tank because is rusted through. Any thoughts on whether rust in the tank would cause the pump to wear out sooner? Trying to gather as many opinions as possible, it's hard to part with $500, but I don't want it to blow next week and then have to pay the labor.
  5. Feb 18, 2015 at 2:39 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    These intank pumps should have a screened foot. If you get it out and there's holes in it or it's missing, time to replace.
  6. Feb 18, 2015 at 3:34 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    $500? What is that for. An OEM Denso pump kit with all new clamps, clips, the little hose and an upgraded pick up filter is $80 from RockAuto.
    Failure starts to get more common at around 175K and beyond. Its your call on when you want to pull that tank again.
    Did it rust thru from the outside or inside?
  7. Feb 18, 2015 at 4:25 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    if the tank rusted through then put a new pump from rockauto.com its the same oem denso pump from the factory without the $400 markup in price.
    if the tank rusted through then it may have had fine particulates going through the pump causing excessive wear that will shorten its life and is it really worth pulling the tank again to avoid spending $80 on a new pump to go along with that new tank?
    and I assume you know to put a brand new inline fuel filter on at the same time (if you have one)
  8. Feb 18, 2015 at 5:13 PM
    Brake Weight
    Modern fuel tanks have a plastic/polymer lining blown inside them. A fuel pump won't ingest rust from a rusty tank.
  9. Feb 18, 2015 at 5:51 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Not so on a 1st gen Tacoma.
  10. Feb 18, 2015 at 6:21 PM
    jid1234567
    Jen
    New York
    02 xtracab 4x4
    Outside, I'm in upstate NY.
  11. Feb 19, 2015 at 11:36 AM
    jid1234567
    Jen
    New York
    02 xtracab 4x4
    Thanks everyone, I just ordered the Denso pump, should have everything done by the end of next week. I'll follow up and let you know how it goes.
  12. Feb 25, 2015 at 3:35 PM
    jid1234567
    Jen
    New York
    02 xtracab 4x4
    Here's a summary of the repairs: replaced rusted fuel tank with Spectra TO31C (18.5 gallon) fuel tank and replaced pump with DENSO 9500103 pump and strainer set. Around $300 total for parts, both from rock auto.
    I didn't replace the lower shield on the fuel tank, I may replace eventually if we do more off-roading than we do now. Suggestions about this are welcome, or get in touch if you have one that will fit my truck.
    Thanks for the suggestions, you all saved me lots of $.
