Replace '14 door "tweeters" with 3" fullrange?
Discussion in 'Audio & Video' started by SlowComa666, Aug 11, 2014.
  1. Nov 5, 2014 at 4:16 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    I would almost go the same route you did, but I got the supplies, and just need the time.
    on a scale of 1 - 10, how much better is that driver than the stock tweeter in that location?
    edit:
    also, how did you tie in the wiring? just make pigtails, connect to the speaker, cut existing wiring and adapt?
  2. Nov 5, 2014 at 4:22 PM
    SlowComa666
    SlowComa666 [OP] Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    it is more efficient and tons brighter. at least a 6. again it is rather "shouty" meaning a rising response.
    cymbals can actually be heard now, vocals project very well.
    i just cut and added connectors.
  3. Nov 5, 2014 at 4:29 PM
    6spd
    san diego
    2023 4x4
    cool.
    what kind of head unit are you using? does it have a parametric eq so you can tone down the shoutiness? does it sound like the speaker is limited from the tweeter hole in the door panel?
  4. Nov 5, 2014 at 4:33 PM
    SlowComa666
    San Antonio TX
    stock deck, don't plan on changing
    clearly not enough power though, i will need an amp very soon.
    probably gonna go with www.minidsp.com for extreme adjustability. i can't see spending $500 for the JBL MS8 or more for things i don't really need.
  5. Nov 5, 2014 at 4:38 PM
    6spd
    san diego
    2023 4x4
    Im thinking of a helix dsp, eventually. lying in wait, I have an mtx 4300(fronts), and a zed minotaur(subs).
    still waiting on subs to come out, and slowly purchasing wiring kit, and other things, as I plan to wire for future, additional upgrades.
  6. Nov 5, 2014 at 4:45 PM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Sub'd. You seem to be going where I would like too. How do you feel about alpine components? Looking to go 6.5 thought front and rear along with a 4 channel amp. Their tweeters and crossovers also..
  7. Nov 6, 2014 at 5:55 PM
    SlowComa666
    San Antonio TX
    i am headed this direction because i don't like any of the prepackaged options on the market. to my ears they do nearly nothing right, least of all raise the soundstage from calf level. with the Dayton RS75's in the upper door i now have decent highs and a soundstage approaching dash level. i will be tweaking them and the crossover this weekend. amplification and 8's for the doors are next on the order list.
  8. Nov 6, 2014 at 7:11 PM
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    Slow - have you verified the RS75's fit there? I was also looking at the Fountek FR88's for that spot - look to be very similar in depth/design.
  9. Nov 6, 2014 at 7:13 PM
    adrenalnjunky
    nvm - I read your post wrong. Did you have any trouble making them fit? Pics?
  10. Nov 6, 2014 at 9:54 PM
    SlowComa666
    San Antonio TX
    pics probably saturday. work gets in the way of these things......
  11. Nov 7, 2014 at 12:49 PM
    PETEREDGE
    PETEREDGE Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,YOKAHAMA MT'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
  12. Nov 7, 2014 at 4:31 PM
    SlowComa666
    San Antonio TX
  13. Nov 7, 2014 at 5:31 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    looks nice, i can tell you that 8s work really well in the front doors. Ib application is perfect with the door size if u can get the panel properly sealed off from the cab
  14. Nov 7, 2014 at 8:05 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    My new set up was supposed to have 4 8s and 4 tweeters to keep up with the bass i was going have but i down scaled the entire project as I'm no longer going to compete with the truck.
    Only going to be running 1 shok 4xl (150x4wrms) to 2 8s and 2 tweeters per door in a full custom door, i can take pictures tomorrow maybe of the progress and email it to you and we can cross notes etc
    azsean likes this.
  15. Nov 7, 2014 at 8:40 PM
    #35
    SlowComa666
    San Antonio TX
    nice nice nice why not post em here?
  16. Nov 7, 2014 at 8:41 PM
    #36
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    i guess i could.
  17. Nov 8, 2014 at 5:32 AM
    #37
    SlowComa666
    San Antonio TX
    MY THREAD!
    MY RULES!!
    your post gave my the hope that non-cookie cutter installs were possible.
    thanks for that.
  18. Nov 12, 2014 at 9:25 PM
    #38
    SlowComa666
    San Antonio TX
    didn't get my doors off last weekend, hopefully this weekend.
    finally got a decent pic of them behind the stock grille, this should give you an idea of what will actually fit. remember the actual cone of this driver is about 50mm [1.9"]
  19. Nov 13, 2014 at 6:58 AM
    #39
    adrenalnjunky
    Thinking I'm just going to go ahead and order a set, and build out my sail panels for my tweets.
  20. Nov 13, 2014 at 7:59 AM
    #40
    SlowComa666
    San Antonio TX
    just to be clear, these drivers full range with no EQ are very midrange forward. if you look at the response graph from Dayton they are 5db up from 1.5kHz-5kHz then a nice falloff to 15kHz http://www.parts-express.com/pedocs/specs/295-380-dayton-audio-rs75-4-spec-sheet-revised.pdf
    i can't hear above about 16kHz [age+air tools+general abuse] so i don't feel there is any information missing where I would want/need a tweeter. these drivers do mids/highs quite well to my ears.
    i would probably add sail panel or A-pillar tweeter to help raise the soundstage a bit more, i still might in the future.
