Replace 17" Sport Alloys with 16" steel wheels ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jben, Dec 2, 2014.
  1. Dec 2, 2014 at 9:49 AM
    jben
    jben [OP] Member
    Ben
    15 TRD Sport
    I have a 2015 Sport with 17" alloy wheels. I have a set of 16" steel wheels with snow tires mounted on them from my previous Tacoma. Can I mount the 16" wheels/snow tires (245/75/16) on my 2015 Sport ? If so, do I need to use the lug nuts that are used on the 16" steel wheels ? Thanks for your help !
  2. Dec 2, 2014 at 10:14 AM
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    not sure about the lugs. the wheels will fit, assuming they're off at 16 inch 6 lug taco.
  3. Dec 2, 2014 at 10:18 AM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    You should be able to use the alloy wheel lug nuts on the steel wheels, like if you had to run the spare tire. It is the other way around that won't work (steel lug nuts to alloy wheel). And the 16" wheels will fit.
