Replace 2015 automatic transmission with manual
Discussion in '2nd Gen. Tacomas (2005-2015)' started by macnarfd, Feb 27, 2025.
  1. Feb 27, 2025 at 3:52 PM
    macnarfd
    macnarfd [OP] New Member
    Andrew
    2015 Access Cab 4x4
    For 35 years, I have driven a manual transmission in my trucks, but the 2015 4x4 I am buying comes with an automatic. I do love the overall sense of driving a standard, so much that I am actively considering the large project of replacing the automatic. How bad is it to retrofit the automatic with a manual? Obviously I need to add even a clutch pedal and replace the center console, but how much work is it overall, and where did you find a useable procedure and maybe even a kit?
  2. Feb 27, 2025 at 4:24 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If you don't want an automatic hold out and buy a manual.
    I've been driving for 50 years and more of the trucks/SUV's I've owned were manuals than automatics. They can be fun to drive, I get that. But modern automatics do everything better. Better fuel mileage, more durable, literally everything especially if you tow or carry heavier loads.
    There is more to it than the transmission. The engines and axle ratios they use in modern trucks are designed around an automatic transmission. Toyota is just about the only manufacturer still offering a manual and it's in only 1-2% of the trucks made. It's just done as an afterthought anymore.
    Ricardo13x likes this.
  3. Feb 27, 2025 at 4:42 PM
    RandyLahey
    RandyLahey Well-Known Member
    Southwest PA
    2013 sport 6mt
    Manuals are usually a little more expensive used from what I’ve seen so you might be able to save a little bit doing a swap if you got a really good deal, however if you haven’t done anything this advanced before it’s probably not the best idea to try it on what I assume is going to be a fairly expensive purchase, your best bet in the end is probably to find one that already has a manual and save yourself a lot of headache
  4. Feb 27, 2025 at 4:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You'll need a Manual ECM, and a Manual 4WD ECM too.
    Not really worth it. It's doable, but it's not just "bolt it".
    Jimmyh likes this.
  5. Mar 1, 2025 at 5:46 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I did it and you can read about my swap in my signature.
    Not cheap, not really easy but now that the kinks are mostly worked out, it's pretty sweet to row through the gears and to have one of the only manual trans DCLB's in the country.
    I found you also need to have the ABS module from the same truck you got the ECM from. There's 8 or more different ABS modules for the various cab configurations and packages for every year and I found it's just easiest to grab the ABS module and the ECM from the same truck. Definitely $300 or so I didn't budget for.
    BassAckwards likes this.
  6. Mar 1, 2025 at 6:18 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Wants manual, buys automatic. WTF am I missing here....
    Dude, this ain't the 70s, when you and a couple of buddies could swap out the power-glide for Muncie in an afternoon. Whole lot more to it nowdays...
    Jimmyh, Ricardo13x and ridefreak like this.
  7. Mar 1, 2025 at 6:58 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    ddddddrrrrraaaammmmmaaaa......
  8. Mar 1, 2025 at 7:27 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    The AT in my truck is the first automatic transmission vehicle since my first car that I purchased just after the Battle of Gettysburg. Big, expensive job changing to manual transmission. If you want manual, buy a manual. You'll get used to automatic transmission. Way easier and cheaper.
    Jimmyh and That one old guy like this.
  9. Mar 1, 2025 at 7:38 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    talk to me about that AT in the gen2 single cab 4wd
    the 3 with the D...
    the refusal to automatically downshift smoothly into 3 when you need to pick up the speed and not impede
    That one old guy likes this.
  10. Mar 1, 2025 at 8:51 AM
    That one old guy
    Chuck
    Stockish
    OTOH, I'll talk to you about the joy of having a manual in a 4X4 access cab with a lowly 2.7! :burnrubber: :D
    Black97v6MT[QUOTED] likes this.
  11. Mar 1, 2025 at 10:26 AM
    Black97v6MT
    iMA0
    tacoLand USA
    Is it the same issueer?
    2,7 seems to have ok power in 3rd at higher rpms
  12. Mar 1, 2025 at 10:48 AM
    TacoTuesday1
    FL
    If one does not have a Tacoma
    And wants a manual Tacoma
    they would buy a manual Tacoma
    and then deal with the throwout bearing crap
    that is coming from someone who has manual converted an automatic “complicated” German car
  13. Mar 1, 2025 at 10:51 AM
    That one old guy
    Chuck
    Stockish
    Nope. Just relating the point that the 2.7 gets along quite well with the manual! :thumbsup:
    And I've towed with it too...:eek::D
    Black97v6MT[QUOTED] and Jimmyh like this.
  14. Mar 1, 2025 at 11:42 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I would have happily bought a DCLB with a manual transmission...if Toyota offered them. Easy enough to find a 6spd access cab, though.
