replace 3rd break light
Discussion in '1st Gen. Tacomas (1995-2004)' started by phil670, Sep 26, 2015.
  1. Sep 26, 2015 at 11:48 PM
    phil670
    phil670 [OP] New Member
    2004 tacoma
    3 inch lifted
    How to remove old 3rd break light
  2. Sep 26, 2015 at 11:51 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    With tools...
    If you want to completely remove the housing, you need to first remove the headliner. There are two nuts that hold it to the body from inside the cab.
  3. Sep 26, 2015 at 11:52 PM
    JohnB81
    JohnB81 Well-Known Member
    OC
    2018 Tacoma TRD Sport 4x4 DCSB
    trifold solid bed cover (Amazon) Pop & Lock tailgate auto lock LED Headlight/ fog lights, reverse lights, dome/plate lights AVS ventshades Smartliner front & rear floor mats Rough Country neoprene seat covers BHLM NiLight LED strip bed lights NiLight RGB LED strip lights behind rear seat storage NiLight RGB LED strip lights for under hood and behind the grill lighting NAVIKS Apple CarPlay interface on stock Entune system Auxbeam auxiliary fuse box/ switch controller Auxbeam custom fit switch panel (Etsy) Coin holder bucket (Etsy) Center console organizer HookeRoad center console vault 32” Slim LED light bar mounted on CaliRaised Offroad lower bumper brackets Suparee sequential turn signals in black smoke OEM bed mat Sokie Tech hood struts 14” Hood scoop LED light bar RGB Raptor lights with smoked lens K&N air filter with TRD air intake accelerator K&N cabin air filter ViAir portable air compressor TuffSkinz interior red color accents on doors and center console TRD faux Pro shift knob w/ TVD TRD decal Glove box letters from Tacos4Cheap MESO customs chrome delete MESO customs door handle blackout covers MESO customs minimalist key fob V1 & V2, red MESO buttons MESO customs puddle lights MESO customs dual color map lights Matte black steering wheel overlay TVD matte black glove box overlay Pedal Commander A/C drain mod Red/Black paracord grab handles Red seat pull straps LOSTAR faux Pro skid plate Rockville 8” powered subwoofer CaliRaised LED catalytic converter plates Hooke Road tailgate panel Rok-Block tailgate gap seal Rear cab USB mod (idea from @ClassyTacos) Xprite RGB rock lights Falken Wildpeak MT 285/70/R17 Painted calipers red w/ TRD decal Akebono brake pads eBay seat jackers 4WP rock sliders DS18 tweeters DS18 front speakers Bought it with: Black Rhino Hammer wheels Spacer lift 285/75/17 Toyo MT’s TRD Pro Grill Hertz Audio speakers/ KENWOOD tweeters
    Two torx screws and peel away the gasket. Unplug wiring harness,... can't be anymore straight forward.
  4. Sep 26, 2015 at 11:54 PM
    phil670
    2004 tacoma
    3 inch lifted
    Thank you
  5. Sep 27, 2015 at 12:39 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    just a word of caution, replace it with an exact replacement oem or it may leak. lots of people put aftermarket 3rd brake lights then have water leaks because they just don't seal like the oem ones do.
  6. Sep 27, 2015 at 12:46 AM
    Caligula
    Los Angeles, CA
  7. Sep 27, 2015 at 12:55 AM
    phil670
    2004 tacoma
    3 inch lifted
    Do I need to take out all the inside roof padding to get to the 2 nuts
