Replace Alternator? ( Update Engine Noise)
Discussion in '1st Gen. Tacomas (1995-2004)' started by RockTock, Jun 18, 2017.
  1. Jun 18, 2017 at 10:11 PM
    RockTock
    RockTock [OP] Well-Known Member
    Colorado
    1999 2.4 4 Banger SR5
    There was a whirring sound coming from my engine. I figured out it was probably because I had run a 1500 watt power inverter off the battery powering a 1450 watt device. I tried again and a similar noise came from the engine compartment.
    The battery shows 14.3 when engine is running, 12.7 at test. So question is do I need to replace alternator because of the noise even though the battery shots a good charge? Nearing 200,000 miles.
  2. Jun 20, 2017 at 3:22 AM
    Lovemystomper
    Lovemystomper Member
    Todd
    Stomped out '02 Tacoma TRD
    Fabtech3.5Lift,K&NColdAir,JBAHEADERS,OptimaPower,PowderCoatedRockBumpsandSliders,RigidLED's,CustomGrill,WeldWheels,CooperSTTPro's,H/DLeafPaks,SmittybuiltWinch and a ThumpingAssSysten!
    I hope my recent issue can solve part or all of your problem.I slowly started getting a blower/gear whine that mostly showed when warmed up.I stethoscoped the alternator and bearings were gone and it sent that sound throughout driver side valvetrain.I have 230,000+ miles on my 2002 3.4 Tacoma and the alternator was stock.Let me know if it helped!
  3. Jun 20, 2017 at 3:50 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I'd look at your idler pulleys, remove the belt and spin each one to see if it turns freely. Don't look at the expensive stuff before you check the cheap stuff first.
  4. Jun 20, 2017 at 8:50 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If your alternator is under a load it's going to whine. That's normal. You put an inverter on it and the noise is there. Your voltage read outs are all normal.
  5. Jun 20, 2017 at 9:24 AM
    RockTock
    Colorado
    Yes volts are still normal. But sometimes I get the whinning noise when no load is on it.
  6. Jun 20, 2017 at 11:48 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If the battery has discharged at all (which is likely the case running a high wattage inverter on it), then you will hear the whine for a bit and it will go away when the alternator is done topping off the battery. This is not uncommon. If I leave my lights on for a period of time and start the truck, the whine occurs for a few minutes until the battery is fully charged again.
  7. Jun 21, 2017 at 7:33 PM
    RockTock
    Colorado
    The inverter was a 1500 watt and 1500 watt load.Too much for this truck. Installed new battery and it's back to 14.3 when at normal idol. I'm having the alt checked anyway. It was whining on me when I was in the middle of nowhere.
