Replace backlight behind temp control knob on the A/C + Heater
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ocean86, Jul 21, 2010.
  1. Jul 21, 2010 at 3:30 PM
    Ocean86
    Ocean86 [OP] New Member
    Santa Cruz, CA
    '02 Xtracab Prerunner V6 w/ Shell
    Camper shell with homemade bed, storage
    Has anyone replaced any of the back-lights behind the AC/Heater controls in the console? Is this hard to get at and worth waiting until there's a better reason to get back there? Or easy enough that I'm gonna kick myself for not having done it already?
  2. Jul 21, 2010 at 4:33 PM
    scocar
    scocar Patron of the Farts
    Man, I just showed someone this in another thread recently. I was going to do a write-up when I have some time.
    It is annoying, but not technically hard. No special tools required. You have to remove the entire center dash cover stuff (start from the bottom and work up), then remove the white temperature control unit and take that apart. The bulbs are twist-locks that insert from the back. Check out my image gallery for the pix titled CDash and Temp ctrl.
