Replace Ball Joints, Links, Tie Rods? OEM, Moog, Proforged, Mevotech?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BenevolentMachination, Aug 12, 2019.
  1. Aug 13, 2019 at 11:18 AM
    ForestRunnerFrank99
    ForestRunnerFrank99 Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
  2. Aug 13, 2019 at 12:01 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
  3. Aug 13, 2019 at 12:06 PM
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    Since we are on the subject...
  4. Aug 13, 2019 at 12:32 PM
    ForestRunnerFrank99
    Josh
    Those are the ones I just bought. I'm feeling pretty good about my purchase now lol.
    CS_AR likes this.
  5. Aug 13, 2019 at 1:13 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I owned/operated a chain of auto parts stores for over 16 years, so know a little about parts/parts quality. I just replaced lower ball joints on my '96 a couple weeks ago and used Moog. Having said that the original Toyota went 412,000 miles.
  6. Aug 13, 2019 at 1:29 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    And??? They were good or bad?
  7. Aug 13, 2019 at 1:30 PM
    eon_blue
    Azusa, CA
    Man my last set of OEM lower ball joints lasted about 55k miles lol. Lot of those miles were some rough 4x4'ing though. They developed a lot of slop/play in them so I changed them out before they left me stranded on the side of the road, or off a cliff
    OneWheelPeel likes this.
  8. Aug 13, 2019 at 1:30 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    The PS line is still going. Good.
  9. Aug 13, 2019 at 2:07 PM
    Kevin Jones
    Kevin
    Va
    They were worn out, but like I said 412,000 miles so no complaints.
    I went with the Moog because I sold Mood parts for many years and never had any problem with them. I toured their plant several times and good people and a first rate organization.
  10. Aug 13, 2019 at 2:10 PM
    Kevin Jones
    Kevin
    Va
    Wow, 55K sucks regardless how it's driven. I'm interested in seeing how my new Moog ball joints last, something tells me I won't be getting another 412,000 miles out of them.
  11. Aug 13, 2019 at 3:03 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Your Moog lower ball joints are just Moog because of the box it came in. Moog doesn't manufacture lower Ball joints for our trucks. They rebox a lower ball joint made by Sankei/555 and sell it. But I have now seen cheap actual Chinese LBJs in AC Delco boxes ordered from Amazon. Buyer beware.
  12. Aug 13, 2019 at 3:09 PM
    eon_blue
    Azusa, CA
    Yeah it really just comes down to the overall crappy design on the lower ball joint on our trucks, the ball joint is constantly under stress to be pulled out of the socket. On the 2005+ Tacomas, Toyota redesigned it and basically flipped upside down so the ball joint keeps itself seated and doesn't want to pull apart. Probably why we never really see or hear stories about later model Tacomas with LBJ failures, but on 1st gens you see it a lot.
    cruiserguy likes this.
  13. Aug 13, 2019 at 3:10 PM
    Kevin Jones
    Kevin
    Va
    That's not surprising as that type of thing is pretty much commonplace these days. Back when had my auto parts stores it was quite a bit different, for the most part if it was in a manufacturer's box they manufactured it.
    cruiserguy[QUOTED] likes this.
  14. Aug 13, 2019 at 3:13 PM
    cruiserguy
    Elijah
    SEKS
    Yep, believe me man, I miss those days too. Companies made their own parts and sold them and you knew who made good stuff, mediocre, etc. No having to try and figure out who manufactured what where and to what spec, etc like it is nowadays. Ridiculous nowadays.
    But the good news is the Sankei 555 joint you likely used is the next best to the OEM ball joint.
  15. Aug 13, 2019 at 3:23 PM
    #35
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    What pitman arm puller do you guys use ?
  16. Aug 13, 2019 at 3:28 PM
    #36
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
  17. Aug 13, 2019 at 3:32 PM
    #37
    Fatal_Paradox
    Bardstown, KY
    More specifically which size works great for our LBJ and our OTR
  18. Aug 13, 2019 at 3:35 PM
    #38
    eon_blue
    Azusa, CA
    I've really only seen 2, a small one and the 'normal' size one that's about as big as the palm of your hand, maybe a little bigger.
    Harbor Freight sells one for about $15 that I use, it's a bit tight to get on but it fits. It's the only size they have that I've seen. The biggest one I've seen in an auto parts store is the same size
    CS_AR likes this.
  19. Aug 13, 2019 at 3:41 PM
    #39
    eon_blue
    Azusa, CA
    yeah I ruined a brand new OEM LBJ by tearing the boot with a pickle fork when I went to remove it, that sucked. Not to mention you really gotta hammer on that pickle fork to get it to work, pitman puller does a much cleaner job
    It's like a jack in the box for me though, gives me anxiety each time I turn the bolt on it waiting for the ball joint to pop out with a loud BANG
  20. Aug 13, 2019 at 3:42 PM
    #40
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    When you're done with lbj's and tie rods if you cut off about a 1/4" on each side you can use it to press back in upper ball joints, if you are replacing uppers I mean. Just use a stout cats claw as a shim in between the puller and the ball joint.
