Replace bench seats in 1st generation?
Discussion in '5 Lug' started by southern4banger, Dec 22, 2011.
  1. Dec 22, 2011 at 4:34 PM
    southern4banger
    southern4banger [OP] Member
    Below The Mason Dixon
    04 single cab base 4 banger 5 lug
    1.5" front spacers, P235 75 R15 General Grabers AT 2, JB stereo, speakers, Power Bass 10" sub
    Been doing some research on this but not really much on the 1st generation ones... So from what I've read the seats from a first generation Tacoma with bucket seats will(assuming you can find them in a
    Junk yard) fit fairly easily into my Tacoma? I don't believe the bench seats have passenger sensors so I wouldn't have to worry about the wiring...
  2. Dec 22, 2011 at 4:40 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I did this conversion on my 97, bolted right in. You might have to change out the seatbelt recievers depending on what year seat you find. I put 2004 seats in my 1997 and the recievers were different, but the belts themselves were fine.
  3. Dec 22, 2011 at 8:46 PM
    southern4banger
    Where would you find the seatbelt receivers, would I have to order them online? Or I read that you could shave down the actual buckle and that would work... What did you do?
  4. Dec 23, 2011 at 4:11 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I did the same thing in my 96 (extended cab manual)
    I found a set in a junkyard from a Reg cab (same era).....seats & console.
    Seats bolted right in.
    The only problem was the center console didn't fit flush to the floor (tranny hump). It rocked slightly even after it was bolted in. Didn't bother me any.....
    If you find seats in a junkyard, then you should be able to find the seatbelt receivers from the junkyard also.
  5. Dec 23, 2011 at 8:02 AM
    oldtacomaguy
    Dave
    SE Conn.
    All I ended up doing was changing the seat belt recievers from my bench seat to the new bucket seats, only problem I had was I didn't get a warning light on the dash when the belts weren't plugged in. Not a problem to me, I always wear them anyway.
  6. Dec 23, 2011 at 8:30 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    I know in the 2nd gen, you can just grind off a tiny bit, and the bench buckle clips right into the bucket receptacle. might work on the 1st gen too.
