Replace diff gearing in automatic with manual
Discussion in '3rd Gen. Tacomas (2016-2023)' started by soggyBottom, Sep 11, 2021.
  1. Sep 11, 2021 at 5:29 AM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    Automatic Tacoma's have 3.909 gearing while the manuals have 4.30. with the difference being close to 10% I'm thinking it could be a cost effective mod.
    Does this make sense? Has anyone done this?
  2. Sep 11, 2021 at 5:33 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    depends on load......weight.....driving environs.......towing
    if U could find 1 cheap at a salvage yard
    otherwise its only a few hundred rpms.........a fun knuckle bustin weekend tho
    shakerhood likes this.
  3. Sep 11, 2021 at 5:36 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    You won't see more than a 100-150 rpm difference
    hiPSI likes this.
  4. Sep 11, 2021 at 5:53 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Don't forget the torque multiplication.
    Cost effective, yes.
    Skydvrr likes this.
  5. Sep 11, 2021 at 6:23 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Aren’t the differentials different sizes? I’m pretty sure they are
    kahanabob, tcjacado and davidstacoma like this.
  6. Sep 11, 2021 at 6:33 AM
    Jowett
    Brian
    North Adams, MA
    Some 4 cylinder automatics received the 8" 4.30 ratio.
  7. Sep 11, 2021 at 7:49 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Did you miss a 0 from that? Think It’ll be closer to 1500 rpm.
    (Edit. No you didn’t. looks like 300rpm, my maths was bad).
    That would probably be perfect for people running 33” tires. V6 auto gearing, can barely handle stock size tires 30~31”, so assuming it fits and is cost effective ( I have no idea on either), seems it would be good for people running 33”.
  8. Sep 11, 2021 at 8:07 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I've done gear changes in quite a few vehicles I've owned . I went from.3.73's to 4.10's and noticed a 300 rpm increase . I've also seen going from 3.90 gear to 4.88 gear a increase of 500rpm
    Just recently I went from a 3.73 gear to 3.89 gear in my Camaro and had increase of 200rpm
  9. Feb 5, 2023 at 9:53 AM
    surfertaco
    surfertaco Active Member
    Andy
    Accesscab Off-road 6spd
    Any more information on this thread!! Would love to learn more as I have an option to throw in a rear diff from a manual and swap it with the auto I just bought
  10. Feb 5, 2023 at 4:04 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Not much to add. If the diff is the same size you could install it but not really worth the seal and oil to replace imho.
    Chew likes this.
  11. Feb 5, 2023 at 4:07 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Might as well get some aftermarket gears installed, there is no telling what you get from the bone-yard.
    Also, if you have 4wd, you need to do the front differential.
    JoeCOVA and na8rboy like this.
  12. Feb 10, 2023 at 8:31 PM
    surfertaco
    Andy
    thank you for confirming. Seems like a hassle but I’m only doing 33’s max. I just have 2 tacomas right now ones a manual but the manual is being sold
  13. Feb 12, 2023 at 4:56 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    You are looking at a few hundred to set the gears up in the diffs. Ring and pinion need to be swapped, that’s new seals, shims and crush sleeve. Then the time and and a new setup labor.
  14. Feb 12, 2023 at 11:58 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    41201-79485 - Front Ring & Pinion, 4.30:1 Ratio
    41201-09C30 - Rear Ring & Pinion, 4.30:1 Ratio
    Jeff
