replace e locker with non e locker.
Discussion in '1st Gen. Tacomas (1995-2004)' started by mewefan, Feb 21, 2020.
  1. Feb 21, 2020 at 8:09 AM
    mewefan
    mewefan [OP] Active Member
  2. Feb 21, 2020 at 8:36 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    No reason that you wouldn't be able to. The 8.4" is the non e-locker rear end. Same width and everything, just different size third member. The 8" rear end is the E-locker one that came in the the TRD's. Make sure it's got ABS if your truck has that too.
    Although if I were you, I'd look for a 8" e-locker rear end to replace it. All the wiring is already there and they aren't super hard to find. Look around on the 1st gen parts for sale on here too.
    Wulf likes this.
  3. Feb 21, 2020 at 8:51 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This ^^^
    https://classifieds.ksl.com/listing/59044799
