Replace factory taillights on 05 Tacoma w/ LED lights marketed for 2009-2012 models ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JMV99, Feb 26, 2013.
  1. Feb 26, 2013 at 9:00 AM
    JMV99
    JMV99 [OP] New Member
    Georgia
    05 PreRunner
    3" Rough Country lift, 285/75/R16 Open Country Toyo AT2, webasto sunroof, leather interior, Waag Brushguard
    I have a 2005 tacoma pre-runner double cab. first year of the 2nd gen. I wanted to put the LED tail lights you see on newer models. I believe this may have started about 2009 ?? I found a set advertised as replacements for 2009-2012, does this mean they cannot be easily used as replacements, or at all. I need to be very certain, thanks for your input, greatly appreciated.. 2005 tacoma does not come up when you use the tab to see if the part fits your truck, but I'm not sure if that is completely certain, since the site may just be presuming a replacement for the only years it was actually an OEM-related product, not the years it additionally would fit perfectly too... Also, are these cheapos if anyone knows, is it a big mistake not to use the actual OEM replacements IF they are compatible, which is the BIG question, plugs, etc.... wondering if I will need to be prepared for some blown fuses in the process of swapping them out....................... THANKS so much...
    http://www.amazon.com/TYC-11-6305-0...TF8&qid=1361897355&sr=1-1&keywords=11-6305-00
    TYC 11-6305-00 Toyota Tacoma Passenger Side Replacement Tail Light Assembly
  2. Feb 26, 2013 at 9:02 AM
    rs5
    rs5 TACOLIFE
    Tampa, FL 33578
    05 DC PreRunner SR5 V6 TRD Off-Road
    K&N Air Intake
    Fits just fine
  3. Feb 26, 2013 at 9:06 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    all 2nd gen tacomas tail lights are the same plugs and same size so youre good :thumbsup:
  4. Feb 26, 2013 at 9:10 AM
    JMV99
    Georgia
    05 PreRunner
    The enhancement seems a no-brainer for $150 range..... I figured there HAD to be a show-stopper... the harness or wiring or plug.... everybody feel this brand will do the trick ?! Thanks guys.
  5. Feb 26, 2013 at 9:16 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    ya they look good...check on here first, sometimes members want to change out their tail lights and post their brand new led tail lights from $100-200
  6. Feb 26, 2013 at 9:16 AM
    spitfire501
    spitfire501 Well-Known Member
    Austin
    Napa, CA
    Just be sure to run a bead of silicone around the seal where the lens meets the taillight housing to help ensure that they are water tight and you should be set :thumbsup:
  7. Feb 26, 2013 at 9:18 AM
    JMV99
    Georgia
    05 PreRunner
    Great tip, that would be the type of small oversight that would bite me.... thanks for the attention to detail on this task.
    Also, wondering if I will need to be prepared for some blown fuses in the process of swapping them out.....
  8. Feb 26, 2013 at 9:52 AM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    I wouldn't expect to blow any fuses; you'll have the lights off when you swap things over.
    You're switching from incandescent bulbs to LEDs though. You may need a different flasher, or have to add resistors to make the turn signals flash at the normal rate. Lots on this in the Lighting section.
  9. Feb 26, 2013 at 10:00 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    turn signals arent led...only the brake, unless he buys aftermarket led bulbs
  10. Feb 26, 2013 at 1:28 PM
    RickG
    Southern NH
    Ahh... right you are. Was still thinking of the ones in the other LED tail light thread that's on page one today. They appear to be all LEDs.
    Never mind; carry on...
  11. Feb 26, 2013 at 1:30 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    No problemo man lol :cool:
  12. Jul 25, 2021 at 2:00 AM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Time to revive a nice old thread.
    Just installed 09+ led taillights on my 07.
    Won’t stop popping the fuse. Any idea why?
    Only thing different in the rear is I’m running an aftermarket tow plug system that piggybacks off the taillight signals and power but that’s it
  13. Jul 25, 2021 at 2:20 AM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Could be a short in the taillights. Try undoing the last thing you did, put the old ones back in and see if it pops. If not, then change one at a time and see if it pops after either side.
    I don't know how your tow plug is wired up, but could you try disconnecting that as well? could be a short in that, or the wiring to it, that got uncovered when you moved the harnesses around.
  14. Jul 25, 2021 at 2:42 AM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    its probably the tow plug tapped signals.
  15. Jul 25, 2021 at 5:34 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Maybe the 12V pin is touching the ground pin the bulb sockets.
    How ghetto is this aftermarket "piggyback" connection?
