Replace head gasket vs whole engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oreo Cat, Aug 15, 2020.
Type of fix
  1. Junkyard engine
    5.4%
  2. Remanufactured engine
    16.2%
  3. Original engine with a new head gasket
    48.6%
  4. 4.7 v8 swap
    29.7%
  1. Jun 21, 2022 at 3:11 PM
    #41
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Thanks. Now I know. :)
  2. Jun 21, 2022 at 6:16 PM
    #42
    captaintofuburger
    captaintofuburger Well-Known Member
    2011 Base 4wd 4banger
    If you're you I'm me, if not then nvm. But I would take a yard engine with a compressions test over a rebuilt on a 225k chassis anyday. A rebuild can be anything between a can of spray paint and a skilled person/company being competent. The latter seems to be more of a rare thing these days. I would find the best bang for the buck pulled engine and toss it in. Chassis already has 225k, spending 2-3x the money on a very low mile engine or full rebuild will not add the value you think it will. If the compression is good, maybe get ahead of maintenance and do the timing chain and put a new t-stat, housing, etc extra parts on while it's easier out of the truck. And since you have it apart might as well ditch the air pumps, evap, egr, etc and just be done with that crap thats gonna break anyways.
    Advland[QUOTED] likes this.
