Replace Leafs w/o special tools?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jcremeans11, Jan 1, 2011.
  1. Jan 1, 2011 at 8:40 PM
    jcremeans11
    jcremeans11 [OP] Well-Known Member
    Jon
    Ohio
    01 Tacoma SR5
    Spectre Cold Air Intake, Michelin XLT's (265/70/16), Escort Solo S3, Grounded Throttle body
    I'm kind of a newbie, and I'm just wondering if you need any special tools to remove and install new, 3" lift leafs?
  2. Jan 1, 2011 at 8:43 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    special. No. I would get a breaker bar and some PB blaster. Make sure you have the right size sockets, i can into that one. The U-Bolts i got were a 23mm.
  3. Jan 1, 2011 at 8:44 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    socket wrenches where all that was needed when I did it, aside from a jack/jackstands
  4. Jan 1, 2011 at 9:14 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Possibly a grinder with a cutting wheel. Depends how your bolts are, I would have one nearby just incase.
  5. Jan 1, 2011 at 9:25 PM
    jcremeans11
    Jon
    Ohio
    01 Tacoma SR5
    Alright, thanks guys
  6. Jan 2, 2011 at 4:08 AM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    second this. I ended up cutting off my old ubolts and front hanger bolt.
  7. Jan 2, 2011 at 7:49 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    C - clamps
    **for holding the other leafs together while you put the AAL in**
