Replace OEM antenna assembly
Discussion in '1st Gen. Tacomas (1995-2004)' started by okii, Aug 2, 2024.
  1. Aug 2, 2024 at 12:17 PM
    okii
    okii [OP] Member
    california
    Tacoma 5spd
    Hello-
    Need help finding the correct OEM Manual Antenna Assembly (Part below the fender with cord to radio). My Tacoma has a manufacture date of 6/1996, but is listed as a 1997 model. I believe the OEM part number is 86300-04020 for the antenna assembly(?). I also believe the matching Antenna Base Ornament (black plastic that sits on fender) is part number 86392-04020, and the chrome castle nut is part number 86396-04010 (or 86396-16020?). The 86300-04020 unit is discontinued apparently. I can find an antenna assembly with part number 86300-04050 readily available for sale. Does any one know if this unit will work on my Tacoma? I’m concerned that the fender profile does not match the profile of the 04050 antenna assembly where it rests against the underside of the fender. Has anyone found an aftermarket unit that works with a 1996/97 Tacoma? Thanks!
  2. Aug 2, 2024 at 12:18 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    All I know is that what metra and crutchfield say works, doesn’t fit at all.
  3. Aug 2, 2024 at 12:35 PM
    okii
    okii [OP] Member
    california
    Tacoma 5spd
    Yeah. Actually spoke to Metra to confirm fit. They agreed their antenna actually does NOT fit.
