Replace power side mirror.....
Discussion in 'Toyota Trucks & SUVs' started by JoeGil, Jan 28, 2009.
  1. Jan 28, 2009 at 8:39 AM
    JoeGil
    JoeGil [OP] New Member
    Hampton, VA
    05 PreRunner
    Need to replace my passenger side power mirror. Dealer wants $345 parts/labor. I can get an after market mirror for 99 bucks. Is there a plug in for the replacement or should I pay the dealer $139 to install and avoid problems?
    JoeGil:confused:
  2. Jan 28, 2009 at 8:42 AM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    You have to take the door panel off to get to the plugs for the mirror. Depends on how mechanical you are. I know it seems it expensive but the dealer won't break your door panel, if so they will replace it, instead of you replacing it if you break it.
  3. Jan 28, 2009 at 9:06 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    I had to replace my driver's side mirror. It's a piece of cake. If you've ever used a screwdriver, you can install this thing.
    Don't be afraid of your truck. It's designed to be easy to work on.
  4. May 17, 2009 at 10:43 PM
    Ali-Paki
    Ali-Paki Member
    Los Angeles
    Tacoma TRD
    What if the mirror is only broken.. i bought a cheap side mirror from ebay but quality is wack.... i just want the mirror. I tried taking the mirror off but aint working. I found couple of screw at th bottom of the console but the mirror wont come out. Help please
