Replace radiator as a preventative measure?
Discussion in '1st Gen. Tacomas (1995-2004)' started by asus611, May 14, 2017.
  1. May 14, 2017 at 9:28 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    He lives in California. People have died out here in state parks w/ gps and cells when their vehicles became disabled and I'm talking about your average vacationer, not an extreme off-roader. I wasn't making the case that he was an extreme overlander, but addressing your comment that people should tow a parts vehicle when they go offroad.
    PROseur and Taco302[QUOTED] like this.
  2. May 14, 2017 at 9:31 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    I don't agree with you here. Because, that would mean all OEM parts manufactured today are inferior to the ones that came on our rigs when they were produced. For sure aftermarket parts can be inferior, but OEM means it meets the spec and quality of the original. So, do you work for the automobile industry and know this to be fact or is this just a general statement, "They just don't make things like they use to."?
  3. May 14, 2017 at 9:35 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Gotta agree here too. The original radiator in my first gen only lasted 10 years and the aftermarket replacement is leaking after 8-9 years so while it may not be a certainty that a new radiator OEM or otherwise will last as long as an original OEM, it's also not certain that an original will last an unusually long time - especially in the heat and cold that some parts of this state experience. Temp fluctuation will do a number on plastic parts - the flip side to hot weather and low humidity. :(
  4. May 14, 2017 at 9:44 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Maybe if he changes his rad he should keep the old one as a spare. If folks are dying in parks bc their vehicles break down, then that should be a good warning to others about survival techniques...haul a shit ton of water and food.
    Dalandser[QUOTED] likes this.
  5. May 14, 2017 at 10:07 PM
    Timmah!
    TIM
    I guess if you just cruise your bitchin truck through the mall parking lot, no need to worry about mechanical failures. You'll just have to delay your latest Facebook or Instagram posting to call for a tow truck while your sipping your double latte.
  6. May 14, 2017 at 10:48 PM
    asus611
    asus611 [OP] Well-Known Member
    CA
    03 Double Cab Prerunner
    Wow thanks for all the responses everyone . Didn't think it would spin off into a huge discussion lol .
    I run an external tranny cooler already from my motorcycle hauling days. The truck is mostly a commuter car / weekend fun car that will shortly become a weekend only car . I'm not doing some of the wild shit I see lots of people doing here. Just love the truck for hauling stuff for my hobbies.
    Have an awesome mechanic doing the labor insanely cheap, I've done work like this before but to be frank I'm older now and lazier. Flat out. Normally I wouldn't throw new parts on just for the sake of being new. But, I guess I was approaching it from the standpoint of "you're in there anyway, and literally the radiator will be removed for the Tbelt so might as well throw a new one in " kind of point of view.
    So, I can do nothing, buy a koyo for $100, or go full Monty and pick up an oem.
    Thanks for input everyone , I'll keep y'all posted !!
  7. May 15, 2017 at 9:37 AM
    Glamisman
    Glamisman Well-Known Member
    I picked up a Denso Radiator from my local radiator shop $120 ish.
  8. May 18, 2017 at 7:23 AM
    asus611
    CA
    Not sure if you guys care, but I actually ended up replacing the radiator with a Koyo. Feedback from my mechanic was that it was a great fit, slid in there no problems. Here's to another 180k miles!
    Dalandser likes this.
  9. May 18, 2017 at 9:18 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Do you know where he sourced it from?
  10. May 18, 2017 at 9:42 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    My 2001 OEM radiator lasted till last month at 201K miles. I replaced it with another OEM. So not bad for 16 years and 200K miles for OEM.
    cruxofthebisquit and keakar like this.
  11. May 18, 2017 at 12:15 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    I guess, if the radiator has lasted this long and you've been diligent with maintenance drain/refills and/or flushes - keep it up
    Assuming you are not visually seeing problems ;-)
  12. May 18, 2017 at 2:06 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Said he replaced it? Both OP and the post before yours?
  13. May 18, 2017 at 2:18 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Is the factory glass safe or replace aswell?
  14. May 18, 2017 at 2:26 PM
    asus611
    CA
    No idea. I just know I told him to get me the cheapest, finest radiator that wasn't $200.
  15. May 18, 2017 at 4:45 PM
    #35
    Tinyredtaco
    Tinyredtaco Well-Known Member
    Brandon
    AZ
    02 DCPreRunner TRD V6
    Bilstien 5100 front/back... Morimoto Projector retrofit.
    Mine just blew at 202k I went from noticing a slight bit of seepage to it failing completely. Maybe its because of the Arizona heat but if i would have known I would have just replaced it the last time I was doing Timing belt water pump. If money is not a problem I would just do it.
  16. May 18, 2017 at 8:23 PM
    #36
    Indy
    Indy Master of all I survey.
    Its covered in the everything else category. Same with the floormats.
