Replace rear speed sensor, code C0215
Discussion in 'Technical Chat' started by TacoTraveler75, Jan 4, 2018.
  1. Jan 4, 2018 at 3:55 PM
    TacoTraveler75
    TacoTraveler75 [OP] Member
    Jeremy
    2007 Silver 4x4 Tacoma double cab
    2" lift, BFG KO2s, TRD exhaust, AEM intake
    Happy new year all!
    Looking for some advice on replacing rear speed sensor on an '07. The dealership diagnosed it for me but I think they're asking too much for the part and the work, I found the part online for much cheaper than they quoted and it doesn't seem like too complex of a job. Just wondering if anyone could give me an idea on the difficulty level?
    Thanks!
  2. Jan 5, 2018 at 7:39 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    disconnect electrical connection, remove bolt holding sensor in place, remove sensor, install new sensor, bolt into place, attach electrical connection.
    TacoTraveler75[OP] likes this.
  3. Jan 10, 2018 at 12:14 PM
    seanislegend
    seanislegend Well-Known Member
    Sean
    Port Richey, FL
    2008 Tacoma TRD Sport 4x4
    3" Icon coilover lift with resi. 17x10 pro comp wheels 255/75/17 bfg km1 mud terrains
    Where is it? Are there two, one for each wheel or one for both wheels
  4. Jan 10, 2018 at 3:22 PM
    TacoTraveler75
    Jeremy
    Thanks JoeyV!
    Sean, there are four sensors, one at each wheel. I'm replacing rear left (driver). From what I've found looks like it's right behind the wheel and just a clip and a bolt. I got the part coming on Friday, will update after install.
  5. Jan 10, 2018 at 3:39 PM
    seanislegend
    Sean
    Port Richey, FL
    I have no idea why I didn’t just use the computer at the shop! I know everything I need to know. Let me know how your install goes.
  6. Jan 22, 2018 at 4:37 PM
    TacoTraveler75
    Jeremy
    Finally got a break in the weather to get this installed. It was incredibly easy, didn't even need to pull the wheel off. Unclip the ABS wiring harness, unbolt, swap em out and done. And I found the part on Amazon for $20 when the dealership quoted me $250.
    gearcruncher likes this.
