Replace Shackle Bushing on a 2018?
Discussion in 'Suspension' started by JonWB, Mar 2, 2023.
  1. Mar 2, 2023 at 1:34 PM
    JonWB
    JonWB [OP] Well-Known Member
    Jon
    Idaho
    2018 TRD OR Access Cab
    I've been digging through old posts for a couple hours, but haven't found anything convincing.
    I'll be replacing my leaf packs with a set of Deavers. The leaf spring will have new bushings obviously, but should I also be replacing the OEM rubber shackle bushing (2018) at the same time? Is it recommended anytime you have the leaf springs out? I don't have any squeaking or indication that the bushing is worn.
    I would likely buy new OEM shackles to avoid the difficult removal of the original bushing. Most posts I've seen use a new poly bushing so I would likely do that also. I am willing to go this route if it is recommended to do while everything is taken apart, but I don't want to add complexity if it isn't necessary.
  2. Mar 2, 2023 at 8:33 PM
    dirt_seeker
    dirt_seeker Well-Known Member
    Utah
    2017 TRD OR
    You don't necessarily need to replace the original shackles/bushings if they are in OK shape. But in my opinion it is 100% worth doing. New replacement shackles (without bushings) cost about $25 and you can put in whatever bushing you want.
  3. Dec 11, 2024 at 9:37 PM
    Dropshot39
    Dropshot39 Active Member
    2017 Quicksand Tacoma SR5
    What route did you end up going and how did it turn out? I'm in a similar situation...
  4. Dec 11, 2024 at 9:48 PM
    Bishop84
    Bishop84 Well-Known Member
    I've re-used them on 2005 models, don't worry about it. They rarely wear out, I've worked at Toyota a long time and we typically only change them because they seize on tundra.
    JFriday1 likes this.
  5. Dec 12, 2024 at 3:26 PM
    Dropshot39
    Thanks, good to know.
