replace wheel bearings, 2WD taco?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bobwilson1977, Oct 20, 2009.
  1. Oct 20, 2009 at 6:04 PM
    bobwilson1977
    bobwilson1977 [OP] Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    My passenger side wheel bearing is starting to make some funny noises. Its a slight ticking sound. Anyhow, I went ahead and got new bearings. I re-packed these bearings probably 5-6 years ago. I totally forgot what I did. I assume its a pretty straightforward procedure on these 4 banger 2WD tacos? All I have to do is remove the cotter pin, retaining nut, and then pull the whole hub off and remove the old bearings?
  2. Oct 20, 2009 at 8:42 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Are you talkin about the front or rear bearing?
  3. Oct 21, 2009 at 6:53 AM
    bobwilson1977
    KaliFORN-I-A
    The front bearings. For the 4WD version the instructions are kind of complicated. But this being a 2WD model I seem to remember you just pulled the hub off, popped out the old bearings, and stuck new ones and seals in. I can't totally recall.
  4. Oct 21, 2009 at 8:52 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    You have it right for the most part.
    What I do is this.
    Remove the front bearing, then put the Nut back on part way.
    Then Pull hard and fast to remove the back bearing seal.
    You have to pull down at an angle to get to to work.
    You you can just use a screw drive to remove the old seal.
    But that takes time. for your won truck time is not an issues.
    Then clean the hub real well and use good grease.
    Repack the bearing and use a NEW COTTER PIN...
    NEVER USE THE OLD ONE.....
    I have seen people loose wheels becuase of this.
    yes it happened and happens.
    Oh note have a few pair of rubber gloves handy. I have 4 to 6 pair and lots of towels...
    have fun...
  5. Nov 27, 2017 at 10:08 PM
    XLundyX
    XLundyX Active Member
    Adam
    1997 Toyota Tacoma 2WD
    Any pics or videos too go along with these instructions?
  6. Nov 29, 2017 at 11:44 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    5lug is easy. 6lug is a press in. You have to take steering knuckle off and put it in a press.
  7. Dec 1, 2017 at 6:45 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Remember to replace the races too. You'll get the best longevity.
    cruxofthebisquit likes this.
  8. Apr 3, 2019 at 9:38 AM
    timdiddy
    timdiddy New Member
    2006 2.7 base extended cab
    I have an 06 base model 2wd. Does any one sell the steering knuckle with the bearing replaced?
  9. Apr 3, 2019 at 9:41 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    tick doesn't really describe a bad bearing though, usually a roar.
    You sure your U-joints are ok?
