Replaced Ball Joints, Breaks acting Strange
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LeBlanc61700, Sep 22, 2011.
  1. Sep 22, 2011 at 1:01 PM
    LeBlanc61700
    LeBlanc61700 [OP] Member
    C
    Mass
    05 TRD Off Road
    kill-switch, fog anytime
    2005 Tacoma TRD Off, Road Access Cab, V6, Auto, 167K miles
    I've recently replaced both wheel bearing assemblies. Went to for an alignment, had to replace ball joints. Did uppers and lowers on both sides with Moogs. Calipers were taking off the rotors. Drove fine for the first 100mi or so, then the brakes started acting up (i.e. Going to the floor, pumping to stop). Bled both front sides and now they seem to grab intermittently, as in occasionally you stop right away or your to the floor and pumping then the truck will lurch and you feel them grabbing.
    Front brakes (calipers, pads, rotors) have been done twice in the past 2 years. 2nd time due to stuck piston. Brakes were fine before doing ball joints. Pry bar was used to back pad off rotor to get calipers off.
    Was told that if bleeding them didn't help it may a bad booster. Any ideas?:confused:
  2. Sep 22, 2011 at 3:58 PM
    Badwin45
    Badwin45 Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    That's odd but may be coincidental. If nobrake lines were disconnected, there shouldn't be any need to bleed the system. A bad booster wouldn't cause the pedal to go to the floor without braking the veh but a bad master cylinder would.
  3. Sep 22, 2011 at 5:26 PM
    pinchetaco
    pinchetaco Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35x12.50x18 Red Letter Generals, ProComp Wheels, Debadged, Black Headlight mod, Dome Light Mod, Trailer Plug Relocated
    From what I understand is that if you have the truck off and pump the brakes and if the pedal gets firmer with each pump then the booster is good... If that is good I'd go with a master cylinder... I had to change mine for a similar issue
  4. Sep 23, 2011 at 4:38 AM
    LeBlanc61700
    C
    Mass
    05 TRD Off Road
    On a scale of 1-10, can anyone rate the difficulty on changing the master cylinder? I've got limited experience.
  5. Sep 23, 2011 at 5:34 AM
    pinchetaco
    Winston Salem, NC
    It's not that hard... As long as you bleed everything correctly including the master cylinder. It's only a couple bolts and a couple of lines
  6. Sep 24, 2011 at 5:27 AM
    LeBlanc61700
    C
    Mass
    05 TRD Off Road
    Anyone know where I can find braided stainless brake line? If I'm going to have to do the master cylinder, I figure I might as well go all out.
  7. Sep 24, 2011 at 8:38 AM
    LeBlanc61700
    C
    Mass
    05 TRD Off Road
    Re-bled both fronts. No consistency on the pedal still, i.e. to the floor, pumping, and grabbing high... Any further input is greatly appreciated. On a further note ABS sensors were unplugged from calipers when doing ball joints, can these be put on backwards, upside down, and have adverse effects? Or would this not affect anything?:help:
  8. Sep 24, 2011 at 7:18 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    :facepalm:
    You have air in ABS system.
    Find yourself long stretch of dirt road, speed up and hammer the breakes until ABS kicks in. Hold the brake pedal until truck stops. Do that few times going forward and backward.
    EDIT: Afterwards you need to bleed brakes again because air from ABS will be pushed into the lines
    or
    you have to go to Toyota dealership to bleed ABS unit
  9. Sep 26, 2011 at 8:35 PM
    LeBlanc61700
    C
    Mass
    05 TRD Off Road
    Seized piston caliper, again, is the correct answer. Anyone else finding this to be a common problem? I don't drive it hard, but I do drive it alot. This will be the 3rd set of calipers going on. 2005 with 167k. Can someone tell me I just got bad parts?
  10. Sep 27, 2011 at 6:48 AM
    pinchetaco
    Winston Salem, NC
    You got bad parts...
  11. Sep 27, 2011 at 7:15 AM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    I'm also having the same intermittent spongy brake problem since about a week ago. Been trying to rack my brain figuring it out before giving in to the stealership. How did u figure it was a caliper piston? This sounds like it makes sense in my case as the problem surfaced out if nowhere without the brake system being opened and with no signs of a brake fluid leak anywhere on the system.
    I don't think I've got a bad master cylinder as the system holds pressure and stops just fine after the pedal is pumped. The pedal doesn't fall to the floor after pumping it up with engine on or off.
    Anyone know a home diagnostic check I can do before making an appt at the dealer? I'd like nothing more than to fix it without them.
  12. Sep 27, 2011 at 3:15 PM
    Slimtv
    Slimtv Member
    Tom
    central IL
    05 DC LB SR5
    I had the same problem about six weeks ago. I unfortunelty took it to the dealer and it was diagnosed and fixed as a bad master cylinder. No fluid leak in the system but the tech thought it might be an internal leak in master.
  13. Sep 27, 2011 at 3:57 PM
    korslite
    Justin
    Bellingham, WA
    DCLB Sport
    Thanks. Some more Google searching convinced me of the same thing. I ordered one today. Should be ready tomorrow. Hopefully avoided a trip to the dealer. Got a reman for $116. I'll chance it on the reman over $270 for the oem. Hopefully its all good.
