Replaced Battery fried Radio
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Pastor, Oct 7, 2022.
  1. Oct 7, 2022 at 3:15 PM
    Taco Pastor
    Taco Pastor [OP] Well-Known Member
    Brian
    2009 Tacoma V6 access cab 6spd Barcelona rec
    Ok, so I fried my radio when I replaced my battery.......the dumb mistakes we make. I couldn't old it right because I hurt my wrist and my entire forearm(chiropractor says I have golfer elbow........stratch my head) and the negative was touching when I tried to connect the positive and ZAAAP! the clock is fine, I have no other extra's, and all my dash is lit.
    I also have a CD stuck in there........how do I get that out? Bash it on the ground, run over it...ect!....LOL!
  2. Oct 7, 2022 at 3:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have to ask, but did you check the fuse for the radio?
    I think the clock is separate from the radio. So it might be the fuse.
    10A Radio No.1
  3. Oct 7, 2022 at 4:49 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Yes the clock is separate from the radio. Like mentioned above, you probably just blew the fuse.
  4. Oct 7, 2022 at 5:41 PM
    Taco Pastor
    Brian
    so you said 10A.....Thanks........
    Otterstuff, wilcam47 and TnShooter like this.
  5. Oct 7, 2022 at 5:43 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Either under the hood fuse box or the one behind the left side of wheel change holder
  6. Oct 7, 2022 at 5:56 PM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Fuse but I prefer to see you irrationally run over it
  7. Oct 7, 2022 at 9:23 PM
    TnShooter
    Deogee
    STOCK
    Correct.
    Under the hood:thumbsup:
  8. Oct 7, 2022 at 10:30 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    What’s a CD? Lmao
    Taco Pastor[OP], winkel and AJKlug1 like this.
  9. Oct 7, 2022 at 10:34 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    On a positive note, at least you didn’t let the positive touch the negative terminal and the negative touch the positive terminal.
  10. Oct 8, 2022 at 2:40 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Connecting the positive wire with the negative already connected should not have caused any fuses to blow. But check them anyway and hopefully you didn’t cross the streams.
    Barrydd and TnShooter like this.
  11. Oct 10, 2022 at 2:39 PM
    Taco Pastor
    Brian
    Ok, under the fuse box lid is a replacement fuse and the tool to pull it. It was the 10a
    Peace,
    Brian
    Otterstuff and TnShooter like this.
  12. Oct 10, 2022 at 2:48 PM
    TnShooter
    Deogee
    STOCK
    Awesome, thanks for the update
  13. Oct 10, 2022 at 2:58 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Hmmmmm, what's in my CD player right now? Best of Guns N Roses.
  14. Oct 10, 2022 at 3:13 PM
    Taco Pastor
    Brian
    4x4spiegel likes this.
  15. Oct 10, 2022 at 3:24 PM
    Taco Pastor
    Brian
  16. Oct 10, 2022 at 3:26 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I have five CDs in my radio that I haven't played in at least four years! I have a Tech Deck with my Garmin GPS and phone mount, that I cant even access the controls without moving that stuff out of the way.
    I play music via a data card in a FM transmitter.
  17. Oct 10, 2022 at 3:31 PM
    Taco Pastor
    Brian
    WOW!........PICTURE PLEASE! I'm interested, very interested.
  18. Oct 10, 2022 at 4:30 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    @Taco Pastor , thanks for the introduction to Glenn Kaiser !! Good luck with the electronics .
