Replaced battery then idle got rough and check engine lights on!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kanaiokilla, Nov 28, 2020.
  1. Nov 28, 2020 at 1:10 PM
    Kanaiokilla
    Kanaiokilla [OP] Member
    Spencer
    Toyota Tacoma 1998 v6 sr5
    3inch suspension lift
    I replaced my battery in my 98 Tacoma v6 sr5 yesterday then the idle became very rough. As well as the check engine light coming on and occasionally flashing.I thought it was just gonna be the ecm taking some time to relearn the idle but I became worried once driving it. While acceleration sometimes the truck would shake all gnarly. So i Took it to oreillys and got the diagnosis. Turns out cylinders 1, 3 and 4 are misfiring. The codes were (P0304, P0303, P0301 and P0300). No idea how changing my battery caused this but maybe it’s just an error???!? Help me out!!! Please and thank you!!
  2. Nov 28, 2020 at 1:30 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    loose connection(s)?
  3. Nov 28, 2020 at 1:32 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    High Noon likes this.
  4. Nov 28, 2020 at 1:32 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    1-4 share a coil pack
    1 is lead cyl pass side
    4 is middle cyl drivers side
    3 is middle cyl pass side
    P0300 is random misfire on multiple cyls
    Has it been humid (heavy dew,rain ) where you live ?
    I’d check plug wire routing and coil connections first. Then maybe consider a good tuneup with quality wires including coil pack boots.
    I’ve had plug boots blow out and arc inside the tube when humid or heavy dew. Coil boots as well.
    Replacing the battery was probably just a coincidence event
  5. Nov 28, 2020 at 1:38 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I'd check the connections too. Clean the terminals really well and check the ground connections as well. If all you did was replace the battery that's most suspect.
    Kanaiokilla[OP] likes this.
  6. Nov 28, 2020 at 2:07 PM
    Kanaiokilla
    Spencer
    I live in Hawaii so it’s very humid but not more than normal. I’ll look into the wire routing
  7. Nov 28, 2020 at 3:40 PM
    Black DOG Lila
    Virginia
    A flashing CEL means
    STOP
    TURN OFF ENGINE
  8. Nov 28, 2020 at 5:05 PM
    MCJohnston
    MCJohnston Well-Known Member
    Matthew
    CT
    02 Tacoma SR5 TRD 3.4L 4x4 X-tra Cab
    Don’t freak out!
    You just need to clean the butterfly on the throttle body. After a new battery is installed the computer is reset. Most commonly on Toyota’s the butterfly position is very fine tuned, you will see behind the butterfly a bunch of black deposits. Spray a rag with brake clean and clean the bottom and top mating surfaces very well. Fixed.
  9. Nov 29, 2020 at 3:23 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
