Replaced dash speakers in non-JBL stereo, 4th gen
Discussion in '4th Gen. Tacomas (2024+)' started by TacoMagic, Oct 12, 2024.
  1. Jan 19, 2025 at 8:41 PM
    #41
    moladin
    moladin New Member
    I ran into the same issue as you from trying to fit JBL Club 34F on the dash. It cannot fit perfectly with the default screws. I had to use smaller screws and washers on one side to make it fit. However, I think the sounds coming from it is worst than stock. No, it was not polarity issue, because I tried both ways by flipping the wire connector to the speakers. So lesson learn, never again I will listen to someone recommendation when the person doesn't even use it themselves. Suffice to say, the JBL Club 34F is going back.
    I am also not sure if using coaxial speaker is a good thing, since the default speaker is one-way. I would assume the built in crossover for the dash speakers are not set to work with 2-way speakers. But hey if it sounds good to your ears, then that is all that matters.
    I might try Audison Prima 4", but one-way not coaxial, since this statement from its feature caught my eye:
    • No passive crossover required to maximize efficiency: the cone is optimized with the Klippel Scan Vibrometer to obtain a calibrated mechanical low-pass cut-off frequency.
    They are $200 a pair however.
    Santytacoma likes this.
  2. Jan 19, 2025 at 9:49 PM
    #42
    Santytacoma
    Santytacoma Well-Known Member
    Santy
    2022 Tacoma TRD Sport 4W
    Mainly stock
    The prima Audison sounds very natural I’m feeding 75 watts in to it and is just clean pure sound
  3. Jan 20, 2025 at 4:18 AM
    #43
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Good info on the jbl club 34f, the guy who initially mentioned them in bobs world thread made it sound like they were a no question upgrade, maybe not so much....
    Do you have the jbl package or just a base model radio?
  4. Jan 28, 2025 at 4:26 PM
    #44
    moladin
    moladin New Member
    I do have JBL system. I think all Pro/Trailhunter come with it by default.
  5. May 23, 2025 at 2:45 PM
    #45
    BillDTacoma
    BillDTacoma New Member
    Bill
    Hey all, a newbie here. My first Taco. 2025 SR5. I want to upgrade the sound system. Non JBL. Added a self-enclosed 10" sub with amp. Want to upgrade the stock PAPER speakers. Started with the dash 3-1/2" speakers. Took out, ordered kicker 3-1/2" . Speakers didn't fit, just too small to fir holes. Try again. I have a few alternates on way to try. Another 3-1/2" and a 4". My main issue is I cant find the correct harness wire adapter! I think I have the right one, order on Amazon and doesn't fit. Not getting a clear exact harness # of what I need online. Any help would be great!! Thanks!!
