Replaced driveshaft...still vibrates
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2x4 tacoma, Feb 26, 2020.
  1. Mar 2, 2020 at 5:28 AM
    #41
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Did you test drive the truck and put it on a lift before you bought it? At least have a mechanic look it over?
    .....Only drive-line issues I've had is U-Joints and Carrier Bearing, and that was at 150-175k.
  2. Mar 2, 2020 at 5:37 PM
    #42
    2x4 tacoma
    2x4 tacoma [OP] Well-Known Member
    Jeff
    2013 2x tacoma
    None
    Pretty much narrowed it down to these rubber band leaf springs now. As the pinion angle is way outa wack from pretty much 15 % throttle to 100%. I watches a newr like 2018 bend the shit out of its leaf springs on take off from a light the other day.smdh
  3. Mar 2, 2020 at 5:44 PM
    #43
    2x4 tacoma
    Jeff
    2013 2x tacoma
    None
    Naw.didnt have access to a lift....i kinda had to buy it quick cuz my frontier was falling to peices faster then i could fix it....trusted all ive heard about tacomas unfortunately noone told me about driveline issues. And im basically a mechanic.dont have all the tools i had now but i was a tech at honda for 6 years, had 2 hotrods and been workin on cars since 20 or 21....thats how i knew there was a driveline issue. I slightly felt it on 2 test drives but you figire out everything wrong w a new vehicle about 2 weeks after you have it.
  4. Mar 3, 2020 at 4:15 AM
    #44
    ToyoTaco25
    North Carolina
    That's too bad you're having a little trouble. If you're basically a mechanic you should know not to just trust what people tell you about a used vehicle and look it over yourself...should have been very easy to notice those leaf springs sagging as much as they are. As with any used vehicle its a roll of the dice because there's no way of knowing how the previous owner treated it. If you could tell there was something off about it after 2 test rides, why would you still buy it?
  5. Mar 3, 2020 at 6:28 AM
    #45
    2x4 tacoma
    Jeff
    2013 2x tacoma
    None
  6. Mar 3, 2020 at 6:37 AM
    #46
    2x4 tacoma
    Jeff
    2013 2x tacoma
    None
    Who looks for sagging leaf springs? I look for oil leaks transmission leaks or sounds. Theres know way to know hidden things about a vehicle till you drive it around for a couple weeks.there auta be a 2 week test period when you buy a used car.but some states do have laws about excessive repairs or problems after a used vehicle is bought. Thats called looking out for the consumer but the rip off state of florida doesnot. So poeple keep getting ripped off....along with toyota not addressing the problem and still putting a 4 leaf spring on these this forum will continue to have complaints about vibrations. They auta call it a toyota vibrator.
  7. Mar 3, 2020 at 6:40 AM
    #47
    2x4 tacoma
    Jeff
    2013 2x tacoma
    None
    Also now that i look at them from my year all the way to like an 18 all their springs are sagging.every last one of em.it evedently has been an ongoing problem for about 15 years now. What coulda been done is me going on a forum before i buy something to pin point the problems as i see them on the page then see if the one im looking at has the same issues.
  8. Mar 3, 2020 at 7:02 AM
    #48
    ToyoTaco25
    North Carolina
    Again, anyone who is basically a mechanic would look over the entire vehicle...
    Sounds about right to be dependent on the government to look out for you when buying a USED vehicle. You should have looked it over before buying it.
    When you point a finger at someone else, there's always 3 fingers pointing back at you.
    whatstcp likes this.
  9. Mar 3, 2020 at 7:12 AM
    #49
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    500 for used springs??
    I threw mine in the dumpster. They aren’t even worth 50 bucks.
  10. Mar 3, 2020 at 7:25 AM
    #50
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    O.P. just get rid of it ,and go buy a Chevy.
    whatstcp, Musubi3, jsi and 1 other person like this.
  11. Mar 3, 2020 at 7:28 AM
    #51
    ToyoTaco25
    North Carolina
    Also, be sure to look on chevy forums so other people can tell you what to look for!
  12. Mar 3, 2020 at 7:37 AM
    #52
    Nachomama2001
    Nachomama2001 Well-Known Member
    South Carolina
    2013 Tacoma TRD OR prerunner
    Bilstein 6112+5160s Air pump delete-Hewitt Technology Rear view mirror switch Hawk pads G2 BAK flip Roadmaster active suspension Seat lifters HVAC AJT knobs
    Garbage leaf springs don’t depend on previous ownership....nor do most of the issues I have had. They are inherent with the truck.
    There are known issues that folks here put up with as being normal.
  13. Mar 3, 2020 at 7:38 AM
    #53
    Nachomama2001
    South Carolina
    Unfortunately I think a Chevy or Ford would be an even bigger turd.
  14. Mar 3, 2020 at 7:40 AM
    #54
    Nachomama2001
    South Carolina
    I bought the Roadmaster active suspension for mine....it keeps a good ride and helps the crappy leafs. $350 I shouldn’t have to spend.
  15. Mar 3, 2020 at 9:04 AM
    #55
    2x4 tacoma
    Jeff
    2013 2x tacoma
    None
    Hahahhahahahahahhahah im not dependant on the government for anything.and when i got 20 other posters that feel the same way i do your point is invalid.lol TOYOTA HAD A PROBLEM THEY NEED TO ADDRESS....i will address it right after i bash em all over the internet...free speach buddy.
    Bobcdn likes this.
  16. Mar 3, 2020 at 9:05 AM
    #56
    2x4 tacoma
    Jeff
    2013 2x tacoma
    None
    Exactly
  17. Mar 3, 2020 at 9:05 AM
    #57
    2x4 tacoma
    Jeff
    2013 2x tacoma
    None
    Exactly
  18. Mar 3, 2020 at 9:36 AM
    #58
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    But the real point is that what you’re experiencing are very well know shortcomings. Very easily found by a google search. I’m not a mechanic and before I buy anything I have a decent understanding of engine construction, common failure points, common weak points, etc of any vehicle I own. Simply so I know exactly what to check for when I show up to look at it. Every manufacturer has its problems dude, leaf springs and driveshafts are pretty fucking cheap compared to the issues others have. Just being honest.
    whatstcp and 6 gearT444E like this.
  19. Mar 3, 2020 at 9:55 AM
    #59
    ToyoTaco25
    North Carolina
    THANK YOU!!! That was my whole point. Its a widely known issue. The BUYER is ultimately responsible for whatever they are buying. And especially a "mechanic", should know to do their homework and at the very least look it over before you buy it. Springs and a driveshaft are much cheaper and easier to replace than an engine or transmission.
  20. Mar 3, 2020 at 12:24 PM
    #60
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    OP, were you able to take it back to the dealer for resolution?
    My 14' has some vibration on take off, but it happened only after I lifted it, so my doing. A single driveshaft would likely fix any issue with vibrations in the driveshaft, but I think you may run into issues with the single DS hitting the carrier cross member (since it sounds like you're stock height). A two-piece double cardan would then be the next solution. I'd run a camera on the underside to see what's happening (i.e. driveshaft vibes/axle wrap).
