Replaced Front Differential at 57,000mi.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dooody, Aug 7, 2011.
  1. Aug 7, 2011 at 5:01 PM
    dooody
    dooody [OP] New Member
    Randy
    Maple Valley Washington
    08 Access Cab SR5 4X4
    :eek: After reading the many opinions on leveling my 4x4 08 Access Cab, I decided to go with the Bilstein 5100's on the front and rear. I had the fronts installed at the 1.75" setting and really like the way it sits. I scheduled a front alignment for the following day at a different shop. After driving about 20 miles home, I was hearing a sound I had not noticed before. I jacked up the left front wheel and as I spun it I could hear a rolling sound coming from the front differential. The right side sounded alright. When I took it in for the alignment the following day, I mentioned it to the technician as I watched him do the alignment. He grabbed the left axle, shook it and said hmm, that seems to be loose. At that time, no fluid was leaking past the seal where the axle enters the differential but within a few days it started to leak. I usually avoid dealerships like the plague, but after realizing it was still just under the 60,000mi. powertrain warranty, I took it in. I was really concerned that they would take one look at the Bilteins and say, sorry you altered the suspension. Fortunately they said the left bearing had spun in the housing and they would need to replace the entire differential and it would be under warranty. WOW! What a relief! 3,000 mi. shy of being out of warranty. But my concern now is will it happen again? Was it just a coincidence it happened just after slightly raising the front? Anyone else experience this? Also on my way home I put it in 4 wheel drive and it sounded fine going in but when I switched it back to H2 it makes a disturbing CLUNK sound. I called and scheduled to bring it back so they can check that out. NOW, this weekend I turned on the AC for the first time in a while (if you live in the Seattle area you'll know why,after all it is only August) and the light on the AC button blinks and it blows warm air. I'll ask about that when I take it in for the clunk. Two weeks ago I was a huge Tacoma fan. Now my confidence has been shaken.
  2. Aug 7, 2011 at 6:21 PM
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
    that would be a HUGE coincidence in my opinion... that the truck has almost 60,000 miles on the clock and it just happened to fail within 20 miles of the alteration...
  3. Aug 7, 2011 at 6:25 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    X2. If it was lift related, you'd be footing the bill.
  4. Aug 7, 2011 at 6:25 PM
    awoit
    awoit Well-Known Member
    San Jose, CA
    08 TRD, SR5, Debadged
    URD CAI, Flowmaster super 40, Debadged, 15% Tint all around, 12" sub, amp, and upgraded kenwood headunit,
    The front left wheel does make a different noise when u spin it while its jacked up then the right one. Some type of "spider" gear or something. This was what was written down when i took my truck into toyota for a few confusing things happening to my truck.. but it sounds like u had some other issues going on, and got them fixed. Well done :)
  5. Aug 7, 2011 at 8:04 PM
    dooody
    Randy
    Doesn't Toyota offer a lift/leveling kit they install at the dealership?
  6. Aug 8, 2011 at 2:05 AM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island, Hawaii
    10 Access Cab TRD OR 5AT 4x4; 08 Regular Cab 5MT 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    Do you have the diff drop installed for your lift? Just wondering...
  7. Aug 8, 2011 at 4:09 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    The "clunk" out of 4WD is normal, mine does it now and then.
  8. Aug 8, 2011 at 4:34 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I don't think they offer one.
  9. Aug 8, 2011 at 11:29 AM
    dooody
    Randy
    No, since I only went 1.75" I didn't think it was needed. Now I wonder whether I should do it.
  10. Aug 8, 2011 at 11:34 AM
    dooody
    Randy
    This shakes the entire truck. I took it back to the dealer today for them to check it out.
  11. Aug 8, 2011 at 11:34 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Some stealerships will sell and install lifts but it's is not associated with Toyota. It's sort of like an aftermarket accessory installed by the dealership.
