Replaced IAC valve today, high idle problem solved
Discussion in '1st Gen. Tacomas (1995-2004)' started by dankgus, Sep 5, 2022.
  1. Sep 5, 2022 at 10:28 PM
    dankgus
    dankgus [OP] Well-Known Member
    Dan
    2002 3.4l Tacoma
    The truck has had intermittent high idle for a while. Actually, the truck has been down for months for head/gasket replacement. Today I started it up and once again the high idle was an issue. A little over 2k rpms.
    I cleaned the disgusting IAC valve and still the problem persisted. I ended up testing the valve with some test leads hooked up to the battery. There was zero action, bad valve. I went to O'Reilly's and picked up a *non* OEM IAC valve just because I was in a hurry but paid basically the same price as OEM. I tested the valve before installation and it worked as expected. Damn, this is an easy part to replace. Fyi, if you suffer from high idle it's probably an easy fix. Clean it and then try using test leads to check the operation. Replace if it doesn't work.
    That is all, just wanted to share my success.
    Bivouac and CPS-65 like this.
  2. Sep 5, 2022 at 11:01 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    i wouldve gotten an oem one
  3. Sep 5, 2022 at 11:16 PM
    dankgus
    Dan
    2002 3.4l Tacoma
    Well, sometimes a guy gets sick of dragging a project out week after week, month after month for the next part that's needed. I use pretty much all OEM parts too but this one was available today. Oh well.
    Madjik_Man and Bivouac like this.
  4. Sep 6, 2022 at 5:40 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I can relate sometimes one needs to get up and running.
    Rather then wait for dealer parts to arrive. Mean while move on to something else in my cases months turn into years.
  5. Sep 6, 2022 at 1:50 PM
    TragicBronson
    TragicBronson Well-Known Member
    Eddie
    Pflugerville TX
    2003 Tacoma Dbl cab SR5 4WD
    Can anybody define what the High Idle range is for the audience? Or what Normal Idle is? TIA
  6. Sep 6, 2022 at 2:00 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Normal idle (in neutral, once up to operating temp, without AC, and all ecu monitors have been run) should be around 750 rpm. All sorts of things can cause the idle to be higher which is why I listed off at least a few of them.
    TragicBronson[QUOTED] likes this.
  7. Sep 6, 2022 at 3:44 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Fsm Inspect idle up speed....
    TragicBronson likes this.
