Replaced injectors now burning coolant
Discussion in '1st Gen. Tacomas (1995-2004)' started by Koda98, Jan 9, 2023.
  1. Jan 9, 2023 at 12:22 AM
    Koda98
    Koda98 [OP] New Member
    Koda
    99 Tacoma 3.4
    Bone stock
    Number two injector failed so I replaced them all, put it back together ran fine but was blowing heavy white exhaust smelled like coolant. Took it apart, the gasket for the iac had failed and coolant was getting into the carb. Replaced gasket now inside of the carb is dry but coolant still present in the intake no change with the exhaust. Did a pressure test and coolant stayed at 13 psi for 15 min no leaks. Had no problems before the injector job.
  2. Jan 9, 2023 at 2:05 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the forum!!
    Just pray tell are you working on that has a carburetor and IAC??
    Give it time to get all the coolant out of the engine
    If it held pressure you should be good to go. Head crack that only opens at operating temperature but will not leak with cold engine at 13 psi.
    Coolant level staying full?
    Good luck!
    Kevins60 and 0xDEADBEEF like this.
  3. Jan 10, 2023 at 7:26 PM
    COTacomaTRDSC
    COTacomaTRDSC Well-Known Member
    2002 Tacoma TRD SC
    TRD black supercharger
    With a bone stock '99 3.4, are you describing a throttle body, rather than a carb?
  4. Jan 10, 2023 at 7:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Imagine OP has a swapped small block chevy hence the carburetor, up front, and maybe a fuel injected engine running the rear wheels?
    Bivouac likes this.
  5. Jan 10, 2023 at 7:30 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW
  6. Jan 10, 2023 at 8:13 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I know little on 5vz's......but can you have an intake gasket leak......and that water damage no.2 injector......
    Any chance you've over heated that engine......
  7. Jan 11, 2023 at 9:01 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    What exactly do you mean when you say "coolant is still present in the intake". The IAC is the only location coolant overlaps with the (upper) intake manifolds. Are you sure you've correctly attached the lines to the IAC, kinda sounds like you may have one of them crossed?
  8. Jan 11, 2023 at 3:24 PM
    Bivouac
    :thumbsup:If that was the case when the IAC opened coolant would flow into the intake .
    When The IAC closed in theory the cooling system would hold the 13psi pressure.
    This is easy to swap lines speaking from experience.:anonymous:
