Replaced Leaf springs now have CEL and Slip indicator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ayeitskooks, Nov 28, 2019.
  1. Nov 28, 2019 at 10:37 AM
    Ayeitskooks
    Ayeitskooks [OP] New Member
    2009 black tacoma
    Hey Guys, so I recently brought my truck to Toyota to get my leaf springs replaced ( recall) and now I have a CEL and Slip indicator light on. Do you guys have any clue what could be going on?
  2. Nov 28, 2019 at 11:04 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I could make plenty of guesses (pull the codes with a cheap code reader, examine the wiring around the wheels sensors etc, maybe they forgot to plug something back in) but in your case you shouldn't be doing anything other than taking it right back to the dealer that did the work.
    Alexely999 and BassAckwards like this.
  3. Nov 28, 2019 at 11:10 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Id also take it back to the dealer. This isnt something you should have to deal with if it wasnt a problem when you initially brought the truck in for the leaf recall
  4. Nov 28, 2019 at 12:59 PM
    Ayeitskooks
    2009 black tacoma
    Thanks guys, yeah I will deff bring the truck back into the dealer this weekend.
  5. Nov 29, 2019 at 7:41 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Someone dropped the axle too low and pulled some wires apart or snagged some by the wheels when putting the new leaf assy in.
    Worse case is that they stretched the wires and internally broke the actual wire while the outer shell looks good.
    Alexely999 likes this.
  6. Nov 29, 2019 at 7:54 AM
    Ayeitskooks
    2009 black tacoma
    Thanks for the reply guys, im here at Toyota getting it check out right now.
