Replaced MAF now it won't idle right
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thewarriordinghy, Jan 2, 2017.
  1. Jan 2, 2017 at 3:18 PM
    thewarriordinghy
    thewarriordinghy [OP] General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    Exactly as title says, replaced the MAF and now it won't idle right... I've replaced them before, but it would always idle right... Ideas?
  2. Jan 2, 2017 at 4:58 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    If thats the only thing you touched, its either bad MAF or its not sitting right and leaking air.
  3. Jan 2, 2017 at 5:12 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Would leaking air at the MAF make it idle at like half idle similar to a vacuum leak?
  4. Jan 2, 2017 at 7:27 PM
    08tacobear
    08tacobear Well-Known Member
    08 taco DCSB pre runner V-6 SR5
    12v accessory plug right rear bed bin,1gallon air compressor setup in left rear bed bin, 3-window bed topper.
    If you jacked with the throttle body at all, like I did once trying to clean it. You will have to have an "idle relearn" by the dealer. Otherwise could be air leak, bad sensor especially if you. Touch the metal part of it at all, even finger prints can jack with it. Or it is after market and it isn't registering. Could e a pipe
    Of things.... suggest going to parts store to have them scan it to see what code it throws.
  5. Jan 2, 2017 at 7:29 PM
    08tacobear
    Btw... does the improper idle you describe acting like low rpm rev from
    About 500 then up to 1000/1200 and back down? If so see above comment about idle relearn.
  6. Jan 2, 2017 at 7:50 PM
    frejil
    frejil Well-Known Member
    Andrew
    2006 Prerunner
    Depo headlights
    How low are you idling?
  7. Jan 3, 2017 at 12:36 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    It stays at like 500.... And it isn't idle relearn, I've dealt with that before...
  8. Jan 3, 2017 at 12:47 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Anytime I've removed my MAF sensor to clean it, my truck always idles funny the first one or two times I start it up until I drive it for awhile. Goes back to normal after that.
  9. Jan 3, 2017 at 6:02 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Something else to think about:
  10. Jan 3, 2017 at 6:05 AM
    AKdude007
    AKdude007 The mountains are calling and I must go
    EAFB
    2007 Tacoma TRD Off-road
    Vision X Light Bars KB Voodoo Bed Rack Tuff Stuff 4x4 RTT
    Have you tried disconnecting the maf while the truck is running for a few seconds and then reconnecting it?
  11. Jan 3, 2017 at 6:25 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    So I put the old MAF on and reset the idle. It was not in limp mode this morning, but I've yet to drive it much. Got it to 4k rpms around the block at my office and it ran normal.
  12. Jan 3, 2017 at 6:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Bad o-ring, bad MAF, incorrect MAF. Where did you get it from, and why did you replace it?
  13. Jan 3, 2017 at 6:49 AM
    AKdude007
    EAFB
    X2 why did you replace it, if the old one works?
  14. Jan 3, 2017 at 6:58 AM
    Beauty or Beast
    Beauty or Beast Well-Known Member
    Jarred
    SWVA
    Magnaflow Off-road exhaust K&N Cold Air Intake CaliRaised Ditch lights/w Rigid D2's Soon to add Pelfreybilt bumper, Headstrong lift, AllPro Sliders
    I had some trouble with this when I installed my cold air intake. It currently idles lower than stock due to the better flow but when I first installed I put it in backwards...idiot mistake, and the truck would run for 5 seconds and die. Might want to double check the orientation of said sensor just to make sure. Did you modify intake or just swap sensors? Before the K&N it held @900-1000, now it runs @700-800 but it's constant.
  15. Jan 3, 2017 at 7:57 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    It had the bad MAF code, have to get an emissions test by Friday, it would crank at normal rpm, then drop to like 500-400. This morning with it cold, I cranked it and let it learn to idle for 35 mins, it sat at the normal 800-900 range, then I drove it around the block and it let me get to 4k rpms where before it wouldn't go over 1900. Had the intake for almost a year now...
    AKdude007 likes this.
  16. Jan 3, 2017 at 7:57 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    I will update this afternoon after I drive it
  17. Jan 3, 2017 at 8:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did you dosconnect the battery before installing the new maf sensor?
  18. Jan 3, 2017 at 8:20 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    After I installed it, then cranked it after having the battery unplugged about 9 hours later after work.
  19. Jan 3, 2017 at 10:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So pretty much because your battery had been disconnected for so long, and the ecu was relearning parameters, yes?
  20. Jan 3, 2017 at 11:19 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Is that how it works? If so I must've pulled off too soon
