Replaced power steering pump, Still no power steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jjhitchen, Feb 9, 2014.
  1. Feb 20, 2014 at 8:42 PM
    #41
    geokelsey
    geokelsey Member
    George
    Occidental CA
    13 AC TDR off road
    I have seem the lining of hoses become separated and plug the hose under suction or perssure. Then reopen making it hard to spot when inspecting. This may be your problem due to the feed hose being sucked shut.
  2. Feb 20, 2014 at 9:09 PM
    #42
    jjhitchen
    jjhitchen [OP] Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Well heres to exploring the unknown. :cheers:
    From my understanding the stock pump is a variable unit that applies more pressure at slow speeds and less at higher speeds and I have seen a range from 1200 psi - 1800 psi so this new PSC pump is rated at 1600 psi, I'll take the chance here.
    I called PSC yesterday and explained my situation and they didn't see a problem with upgrading to their pump.
  3. Feb 20, 2014 at 9:24 PM
    #43
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Yes. Someone is doing it! I really hope you can turn easier when stopped. Air down those meats and tell us how it goes with the new pump
  4. Feb 20, 2014 at 9:29 PM
    #44
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    It will be here monday, I will definitely keep this updated with my success/blown power steering rack. I am also going to add a steering fluid cooler inline to keep temps down. In theory, if this pump is constant at 1600 psi I will have an easier time turning my tires a slow speed, rather than the 1200psi psi at idle which ramps up to ~1800psi or so when you step on it.
  5. Feb 20, 2014 at 9:30 PM
    #45
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Could definitely be the case, but its over now. I am replacing everything but the rack.
  6. Feb 20, 2014 at 9:34 PM
    #46
    Spoonman
    Jamie
    Alberta
    Pressure in our systems should be higher at idle/slow speed, and lower at higher speed. That's to Keene need most assist when in a parking lot or slow speed turning, and less when we're going faster. I am staying tuned for results.. I'm glad you're having a go at this!
    Getting new lines made up too yes?
  7. Feb 20, 2014 at 9:44 PM
    #47
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    How do you figure? If the pump is belt driven off the motor as the motor increases rpm the pump would as well, maybe I am missing something.
    Either way the pump system is on the way, includes pump, reservoir, all lines and connections. The PSC pump strictly says do not use ATF fluid and to use power steering fluid so that is something else I will have to experiment with, putting "power steering" fluid into the system and through the rack instead of ATF Dex II-III
  8. Feb 21, 2014 at 6:04 AM
    #48
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Use Amsoil Tractor Hydraulic Fluid.
    1186009d1390408913-hydro-assist-fluid-qu_412ea8321e904b4ba14cc17f788e0101036619ab.jpg
  9. Mar 2, 2014 at 2:57 PM
    #49
    Spoonman
    Jamie
    Alberta
    So this is a psc pump on the 4.0. Pic stolen from awsumdc. He said its a close fit. Hmmmmmm.....
  10. Mar 2, 2014 at 11:24 PM
    #50
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Works pretty damn well so far! Install went well, definitely not just a plug and play system though. After install I did a pretty hard test run yesterday and was cruzin 60-65mph through moguls and whoops with my hands barely gripping the wheel again, power steering is niiiiiiiice :cool:
    Torspd likes this.
  11. Mar 3, 2014 at 5:54 AM
    #51
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Glad its working for you!
  12. Mar 7, 2014 at 10:25 AM
    #52
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Subscribing because... I like alternate parts :)
  13. Nov 2, 2014 at 9:33 PM
    #53
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    8 months later and the PSC pump kid is doing just fine:cheers:
    The rack on the other hand.. it needs replacement every 6 months now:facepalm::rofl:
  14. Mar 1, 2015 at 1:36 PM
    #54
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Bump
    its 3/1/15
    over a year later and the pump and reservoir are still kickin
  15. Mar 1, 2015 at 9:55 PM
    #55
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The racks still blowing every 6 months?
  16. Mar 2, 2015 at 10:05 PM
    #56
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Yes sir!
    I am due for another soon, the power assist is starting to drip fluid out of the rack. Pump still going strong.
  17. May 8, 2015 at 2:48 PM
    #57
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    My power assist sucks. Blew my rack some years ago and ran the pump without fluid for a period. I've since replaced pump and rack but have never regained nice solid/easy/no steering back/ type performance. What pump is this exactly and how hard was it?
  18. May 10, 2015 at 7:58 PM
    #58
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    What on earth is destroying the rack? They have tiny check valves that do not like trash from a self-destructed pump, for sure. I assume all the trash was either removed by flushing or you replaced all the lines? I've never heard of a 6 month life cycle for a rack of all things... Pain in the ass to pay for it, and a double pain in the ass to replace it.
  19. May 10, 2015 at 8:49 PM
    #59
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Probably over-pressure. Need to find out the operating pressure for the rack, then install a pressure relief valve on the pressure line that'll dump the excess back to the reservoir.
  20. Mar 6, 2016 at 12:12 PM
    #60
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    2 years later and the PSC kit is still working flawlessly.
