replaced radiator
Discussion in '1st Gen. Tacomas (1995-2004)' started by VintageFast, Nov 14, 2014.
  1. Nov 14, 2014 at 5:55 PM
    VintageFast
    VintageFast [OP] Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Replaced the radiator now the heater doesn't seem to get as hot as before. I replaced the rad cap and it got somewhat better. Any suggestions? Thanks folks
  2. Nov 14, 2014 at 6:11 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Hey Jim,
    May be air locked....meaning that air may still be in the system. One way ( at least on my 04 ) to check is to get the engine to operating temp, turn the heater on full blast, open the hood and check the coolant control valve that allows coolant to the heater core. Make sure coolant is flowing thru it with both the inlet and outlet getting hot. You will also have a hose coming out of the firewall that is a heater core discharge, it should also be hot.
    On my 04 heater coolant control valve is under the hood and screwed to the firewall almost right on center. It will have a cable coming from the inside controls.
  3. Nov 14, 2014 at 7:43 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    if you used a double core radiator for better cooling it also means it will take longer to heat up the heater core too
  4. Nov 17, 2014 at 12:11 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I bled the air out and all is fine now.
  5. Nov 17, 2014 at 12:51 PM
    CD20H
    Ben
    North Texas
    Well GOOD!!! Love a easy fix.
  6. Nov 17, 2014 at 12:52 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    What exactly did you do to bleed it out??
  7. Nov 18, 2014 at 12:50 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I took the cap off and let it run for about 15 minutes. Forgot the cap was off and revved it a little. A gusher of antifreeze volcanoed out and poof, no more air bubbles.
