Replaced rear springs-Now Front End Too Low
Discussion in '2nd Gen. Tacomas (2005-2015)' started by firstnamemike, Oct 31, 2014.
  1. Oct 31, 2014 at 5:57 PM
    firstnamemike
    firstnamemike [OP] Active Member
    Chicago
    2011 Tacoma Access Cab 2.7L manual
    Old Man Emu N140S NitroCharger Front Strut Set Old Man Emu 2885 Front Coil Set, General Spring rear springs, Bilstein rear shocks
    First, Thanks to my fellow members I would like to thank Tacoma World Forums for a great resource.
    I just replaced the springs on my Tacoma for the second time, so this time I went with some heavy duty springs from General Spring.
    I really love the added heavy duty strength, and I actually like the added 2-3 inches. Now I think I should bring up the front. See the pictures.
    Does anyone have any suggestions?
  2. Oct 31, 2014 at 6:01 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    U still running the stock rear shocks? If you got 2-3 inches of lift out of those springs ur gonna want to replace those with some longer shocks before you snap them off. Ur best "affordable" choice for ur front end is gonna be bilsteins with eibach or OME springs, or OME shocks and springs
  3. Oct 31, 2014 at 6:09 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Be sure to give the new springs time to settle before you make any final decisions on ride height. They will settle probably 1-2"
  4. Oct 31, 2014 at 6:25 PM
    firstnamemike
    Chicago
    Ok Thanks for the input. Terrance, I did not change the shocks, so I will look into that. And Lynd, I have let them settle for 1 month and they are still much higher than the stock springs.
    I'm going to look into the Eibach or OME shocks and springs as Terrance suggested. I will report back for everyone benefit.
  5. Oct 31, 2014 at 9:08 PM
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
    My truck looks like yours right now. I went with wheelers hd springs and bilstein 5100 all around. I only installed the rear suspension so far, but I have ome 884 coils for the front. My delay in installing them is because of my bad front wheel bearings. I need to fix that first.
