Replaced Shocks and struts and now my ride is not as smooth. Please advise.
Discussion in 'Suspension' started by naturemike, Jun 21, 2020.
  1. Jun 21, 2020 at 4:45 PM
    naturemike
    naturemike [OP] New Member
    mike
    2008 Toyota Tacoma SR5 4x4 TRD Sport
    Hello,
    let me start off by saying that I'm defiantly not a mechanic.
    I recently had a shop replace my struts and shocks on my 2008 Tacoma Sport. The mechanic used KYB Excel - G Shocks and Struts. Now I can feel every little imperfection in the road. I'm curious if these are bad struts or if they were potentially installed wrong.
    I'm planning on taking my truck back in, but I'm wondering if I should be asking for a different brand. The leaky struts and shocks that were on the vehicle rode smoother than the new ones.
  2. Jun 21, 2020 at 4:53 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Probably because they were worn out.
    Try Monroe Sensatrac, but your old stuff is old. New stuff is new. Ride will not be the same.
  3. Jun 21, 2020 at 4:58 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    What do you like doing with your truck? Are you always on pavement or do you like going offroad ?
  4. Jun 21, 2020 at 5:30 PM
    naturemike
    mike
    I use it as my daily driver but I also like to do off road driving as well. Nothing too crazy, but I have to drop it into 4WD from time to time. I drive two track trails quite often.
    DavesTaco68[QUOTED] likes this.
  5. Jun 21, 2020 at 5:41 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    If you don’t like the KYBs, you’re probably going to feel the same with the other brands.
  6. Jun 21, 2020 at 6:47 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    You can check out the suspension forum, lots of good info.
    If your on a budget Bilstein 5100s, Rancho 9000, are fairly cheap.
    https://www.tacomaworld.com/forums/suspension.18/
  7. Jun 22, 2020 at 12:48 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    I’d recommend Bilstein 5100s or some other similar system tuned for the Tacoma. It sounds like the suspension you got was perhaps a bit more stiff than you wanted, perhaps a performance style shock. 5100s ride much better, as would Eibach or OME
  8. Jun 22, 2020 at 2:12 PM
    naturemike
    mike
    What are your thoughts about leaving the KYBs in the back but replacing the front struts with Bilstein?
  9. Jun 22, 2020 at 2:14 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Your new shocks are new. You've gotten used to the pillow soft ride that your clapped out old ones provided. Any brand of new shock is gonna feel stiffer than a worn out old one.
    Hamer95USA likes this.
  10. Jun 22, 2020 at 4:37 PM
    jmauvais
    NorCal
    ...stuff
    I don’t have any experience with KYB so I can’t provide insight on that. You can try it out and see if you like it, if you don’t like the feel in the back, you can always add in new rear shocks later.
