Replaced Shocks, Sill Rides Rough
Discussion in 'Suspension' started by LTdangle, Mar 23, 2013.
  1. Mar 23, 2013 at 11:44 PM
    LTdangle
    LTdangle [OP] Member
    Denton, TX
    Prerunner SR5
    Hey Folks I could use some great advice or direction to see what I can do to fix my truck. I replaced my factory wheels with 20"Enkei's and nitto terra grappler tires. Had an issue with contact inside my front driver side tire well. Vehicle was salvaged so I had the frame straitened out and replaced the shocks with Bilstein 5100's all the way around. Coilovers were replaced from a 4x4 that had only about 10000 miles on them. As I of course gave it a small lift after putting the billy's on there, I had the alignment and balanced tires done repeatedly. I just rotated the tires after a few thousand mile but my problem comes when I hit a little bit bigger potholes. There is some kind of humming sound that occurs during acceleration as well but I'm more concerned about the dramatic bumps in the cabin as I'm driving down regular street roads that have an occasional bump or 2. I also have some kind of squeak coming from that same from driver's side that I assume is from the LCA bushing (a buddy of mine told me silicone bushings can cause squeaking) that I think was replaced when the truck was salvaged, Nonetheless I'll cut the laundry list of crap that I need to get done with my quick silver down to just the suspension problem...Thanks for the help. I'll see if I can put some pics up if y'all think it'll help.
  2. Mar 24, 2013 at 2:24 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I really don't know how to answer .... I'm sorry
  3. Mar 24, 2013 at 6:48 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, HomerTaco Raptor grill, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Toyo AT2, Avid light bar
    What size tires are you running and how many plys?
  4. Mar 25, 2013 at 9:27 AM
    LTdangle
    Denton, TX
    Prerunner SR5
    they're 265/50/20 tires, but I'm sorry I don't know what plys are
  5. Mar 25, 2013 at 9:37 AM
    Large
    Large Red
    When this guy says those words, it's pretty much hopeless.
    Lol, joking. Rough is a relative term, I would go with 1-10, 1 being a Cadillac and 10 being a tank, where are you at here?
  6. Mar 25, 2013 at 9:47 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    The lower-profile 50-series tires are probably contributing to the rougher ride. Stock aspect ratio is 75.
    If your tires were contacting the wheelwell before the lift, they will still contact after the lift when the suspension articulates (as it would when you hit a bump in the road). However, 265/50-20 is only a 30" tire (smaller than stock), so it shouldn't contact unless the wheel's backspacing is really wrong.
    Hum under acceleration is likely driveshaft U-joints. Hum at a constant road speed is likely worn wheel bearing.
  7. Mar 25, 2013 at 9:50 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I mean, honestly, those 5100's are a little stiff. They eat up bumps pretty well once you get some speed...but potholes and rough road, makes it feel like you're on a rocky trail lol. IE my street lol...hate going down it, as theirs kids always around so I always go super slow and just bounce around the whole time. About to replace my entire suspension anyhoo...hopefully the compression adjusters help :D
  8. Mar 25, 2013 at 10:34 AM
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    If you have never done the bearings and you already have over 80k miles than that's your problem especially after upgrading to bigger tires or rims, common problem with prerunners. Mine went out at 90k miles and they were dry as a bone from the factory. If you like doing your own repairs you're in for a treat with those bearings. There are several diy threads with pictures around here just do a search, or get up with me and i'll try to help you with that since I already replaced mine last year. good luck man.
  9. Mar 25, 2013 at 10:41 AM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    Did you lift it with the bilsteins or use a top spacer? Do you get brake squeal? I'd jack up the front wheels and check the bearings. And the Lo Profile tires sure aren't helping your ride
  10. Mar 25, 2013 at 11:28 AM
    LTdangle
    Denton, TX
    Prerunner SR5
    I'm good with streamline roads and highways when there's not much displacement with cracks, potholes,...and other inuwindows lol. Any how rating is a 5 for regular roads and 10 for ghetto roads.
  11. Mar 25, 2013 at 11:33 AM
    LTdangle
    Denton, TX
    Prerunner SR5
    I thought that maybe the low pros were possibly the cause but that's not it. I raised the ride height to the 1.75 mark...cuz it's just better to have it lifted when you can (and little effort). The front is about even with the back, no pun intended. No brake squeals and NO spacers. just had the tires aired and rotated and that helped with the shaking and it rides smoother...but not when going across the jagged blacktop.
  12. Mar 25, 2013 at 2:02 PM
    LTdangle
    Denton, TX
    Prerunner SR5
    Thanks, I'll bet that's it because the truck just hit 80K so I'm absolutely sure that it needs that done (among other things)...thread searching it is
  13. Mar 27, 2013 at 11:00 AM
    LTdangle
    Denton, TX
    Prerunner SR5
    No more contact with the tire and the tire well thank god...just riding durty now...durty/bumpy. It took me one wrong order to figure out the backspacing issue and that was enough of a learning curve to not make that mistake again :mad: but now I'm happier with the ones that I've got.
    Update: 07/01/2013
    now I've ordered 2 lower ball joints, 2 sway bar end links, and 2 wheel bearings (all moog) and definitely will be tied up for a while when I start working on it. I am thinking to go ahead and get all the u-joints replaced in the drive shaft to go ahead have some grease zerks for all these joints anyways. the next thing that I'm probably going to have to get is a new rack and pinion. maybe I won't need a full new rack but I'll definitely need the advice. the trucks makes a pop sound when I take a turn pretty well, and definitely so when couple with a good bump in the road while turning..not really sure at this point if it makes a pop sound during straight road bumps. anyhow, pics are coming up next...hopefully advice after that :)
