replaced stock speakers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by animal93, Mar 15, 2011.
  1. Mar 15, 2011 at 8:33 PM
    animal93
    animal93 [OP] Well-Known Member
    lupe
    weslaco texas
    2008 perunner
    i cut out the inner speaker and used the outer spaeker as an apater.
  2. Mar 15, 2011 at 9:34 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    I bought the adapters, but can't decide what speakers to go with. What'd you choose and how do you like them? What'd you do about tweeters and crossovers?
    RZ Rob
  3. Mar 15, 2011 at 10:53 PM
    animal93
    lupe
    weslaco texas
    2008 perunner
    i went with the kicker ks series built in tweeter and kept factor tweeter sounds like i added a sub
  4. Mar 16, 2011 at 6:20 AM
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2010 2.7 4x4 AC
    Are you also running an amp or just off of the factory or aftermarket head unit?
  5. Mar 16, 2011 at 9:21 AM
    animal93
    lupe
    weslaco texas
    2008 perunner
    no amp
  6. Mar 16, 2011 at 10:46 AM
    crashnrondo
    Ron
    Wisconsin
    2010 2.7 4x4 AC
  7. Mar 23, 2011 at 8:08 AM
    animal93
    lupe
    weslaco texas
    2008 perunner
  8. Mar 23, 2011 at 9:25 AM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Does that head unit works with the steering controls? If so, what is that unit?
  9. Mar 23, 2011 at 12:31 PM
    animal93
    lupe
    weslaco texas
    2008 perunner
    i'm not sure.
  10. Mar 23, 2011 at 4:23 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '10 4x4 DC SR5
    WeatherTech liners, Kenwood Media Receiver, Alpine S 6x9 speakers, Sound Ordnance 8" Sub, OEM running boards, MK6 wheels, Dynapro ATs, Tint, Bed Mat, Avid Light Bar, Rigid 20" LED bar, Truxedo Lo Pro Tonneau Cover
    I did the same thing with some Alpine S 6x9s. Highs and mids are a lot better. I need a new HU to really drive the lower end though. I also have a slight rattle on the right door I need to diagnose. Have the dynamat, just need some time to do it.
  11. Mar 25, 2011 at 10:17 AM
    Polymerhead
    Missouri
    '10 4x4 DC SR5
    Pulled the door panel again today, and rerouted the wire harness because I though it might be the source for the rattle. Replaced the panel and it was still there. After feeling around on the panel I realized it was the speaker cover portion of the door panel that was rattling. I don't know if it was because I had to trim as you did in your first picture, but that's my initial thought.
    I pulled the panel again and dynamatted around the speaker cover and reinfirced the "fins" that run across the facr of the speaker cover. No more rattle! Definitely a more solid sound out of that door now. Now to pull the other door and dynamat there!
  12. May 10, 2011 at 5:58 AM
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    I'm replacing my front 6x9 speakers in my 2011 AC and plan to use the existing speaker adapter exactly the same as the OP did. If I do it this way, will I still need speaker harness adapters, or will the existing harness plug still plug into the speaker adapter and then (I assume) there's wires that will then attach to the speakers??
    If I create my own speaker adapters, what is the p/n for the speaker harness that I should get??
