Replaced tires and now my TPMS light is on.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ray, May 19, 2015.
  1. May 19, 2015 at 2:12 PM
    Ray
    Ray [OP] Well-Known Member
    San Diego
    09 Pre-Runner
    I put new tires on the truck Thursday and will driving late Monday night my TPMS light flashed for about a minute then went steady on. Checking the owners manual, it indicates a TPMS malfunction.
    When the tires were being installed, the installer detached the TPMS from the rim, dropping it into the tire. He then broke the beads, pulled one bead off the rim, then reached in and remove the TPMS. Before installing the new tire, he replaced some parts in the TPMS and installed them back into the rims.
    Anyone have this happen and if so, what was done to fix it?
    Thanks,
    Ray
  2. May 19, 2015 at 2:13 PM
    Aw9d
    Aw9d That one guy
  3. May 19, 2015 at 2:20 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    TPMS sensors need to be reset or re programed.
  4. May 19, 2015 at 2:23 PM
    Ray
    San Diego
    09 Pre-Runner
    Just tried to re-set the system.
    No joy.....still indicating a malfunction.
    I've made an appointment with the shop tomorrow afternoon.
    Ray
  5. May 19, 2015 at 2:29 PM
    ODNAREM
    Ron
    It may just be one of the sensors that needs re programed.I've heard on the forum that can be the case.I've never had any issues myself but hope its minor for you Ray!
  6. May 19, 2015 at 3:33 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    TPMS should not need reprogramming after tire change. It sounds like the installer screwed them up.
  7. May 19, 2015 at 8:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This. I agree Hans. They should not need to be programmed or anything else, they are using the same sensors. He broke at least one of them.
    Jasenice likes this.
  8. May 19, 2015 at 9:06 PM
    4OYOTER
    4OYOTER Well-Known Member
    Alan
    Cedar Park, TX
    4Runner
    Does the TPMS light flash now when you start the truck? Its possible one of your sensors died (battery died) and it coincidentally happened shortly after your new tire install. Not likely, but possible
  9. May 20, 2015 at 8:07 AM
    Ray
    San Diego
    09 Pre-Runner
    It flashes for about a minute then stays on. Owners manual says that this indicates a malfunction in the TPMS.
    Ray
    PS: Thanks for all the ideas. I'll report back this evening with the diagnosis/repair results.
  10. May 20, 2015 at 12:37 PM
    RileyLAFD
    RileyLAFD Well-Known Member
    Riley
    City of Angels
    '14 DCLB Magnetic Grey
    I guess I've got to start this very soon....
    Light from hell never goes away.... not worth paying to take each tire and wheel apart to find/replace sensors. check tire pressures and leave it be. Nothing to lose sleep over.
  11. May 20, 2015 at 12:42 PM
    Jasenice
    Jasenice Well-Known Member
    Socal!
    Icon Stage 4 Suspension Total Chaos UCA Stealth Custom F5 Hankook Dynapro MT 33in CBI ARMOR
    I put the stock senors on aftermarket wheels and no lights came on afterwards! Def go back to the shop and get it check out.
  12. May 20, 2015 at 6:56 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I'm assuming you checked your tire pressure....
    RileyLAFD likes this.
  13. May 21, 2015 at 5:26 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    the person doing the job broke one of the sensors
    they should remove them install new orings install them again
    with a techstream you can tell which one is busted (afaik)
    go back an demand they find and fix the bad one (could be battery too)
  14. May 21, 2015 at 5:36 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    Curious if you had made it back to the shop yet for follow up. As other stated, tire change shouldn't make that go off. People get new tires all the time. When I got new ones on mine and the wifes Rav4, I never had any issues. If the tech dropped it in the wheel, most likely something was knocked loose or broken.
  15. May 21, 2015 at 3:45 PM
    Ray
    San Diego
    09 Pre-Runner
    Shop pulled codes and found two bad sensors. We also dropped the spare and it only had 10-psi so we aired that up, cleared the code(s) and the light re-set. I've driven about 100-miles and it hasn't come on again so we may have got it.
    I know the tech didn't drop or mis-treat the sensors as I was with him the entire time.
    Ray
