Replaced two idler pulleys, now belt squeaks upon accelerating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ekoziko, Jan 29, 2017.
  1. Jan 29, 2017 at 6:46 PM
    ekoziko
    ekoziko [OP] Member
    Eric
    most part stock 06 TRD sport double cab with long bed
    A couple weeks back I got two idler pulleys replaced after the bearings went bad and were making a grinding noise. Last week I noticed, what I think is my belt, is squeaking/chirping like a bunch of birds when I accelerate, the moment I let off the gas, it stops. Any ideas? Is it belt tension? It's driving me nuts
    Thanks
  2. Jan 29, 2017 at 6:48 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Did you replace the belt tensioner pulley, too?
  3. Jan 29, 2017 at 6:51 PM
    ekoziko
    ekoziko [OP] Member
    Eric
    No I replaced just the two idler pulleys with the same Part #, I wouldn't suspect all the pulleys to be crapping on me.
  4. Jan 29, 2017 at 6:52 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Well, it's time to suspect
  5. Jan 29, 2017 at 6:53 PM
    ekoziko
    ekoziko [OP] Member
    Eric
    I'll have to check it out this week
  6. Jan 29, 2017 at 6:59 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    its not a matter of the pulleys but the spring tension of the tensioner itself. age and miles the spring relaxes, if its over extended when installing belt, or allowed to "snap" back unloaded or loaded, that is also detrimental to spring life.
    change the tensioner and the belt now, belt is glazed from slipping, you won't keep it quiet for long if just replacing tensioner.
  7. Jan 29, 2017 at 7:00 PM
    spinglow
    spinglow Well-Known Member
    cory
    Oregon
    2015 tacoma dcsb trd off road
    Try changing the Direction of the belt take off and flip sometimes it works!!
