replaced upstream sensor but PO420 bank 1 code still fires
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, May 23, 2012.
  1. May 23, 2012 at 5:05 PM
    prerunnerSD
    prerunnerSD [OP] "I Brake for Tailgaters"
    Northeast USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    Replaced the upstream sensor with a brand new denso oem upstream sensor that i purchased from ebay...
    check engine light comes on after a few days with the same original check engine code that sparked this in the first place "
    PO420, "Catalyst system efficiency below threshold Bank 1" (this is the only code it shows)
    wondering if the new sensor could be bad or is there likely a deeper problem and what should i do now to tackle this.
  2. May 23, 2012 at 5:17 PM
    trdsteptaco
    trdsteptaco Member
    jeremy
    mass
    02 taco trd step
    most likly the sensor is ok along with your old one. primarly p0420 is the result of a bad cat or a bad seconday 02 sensor. the whole job of the secondary 02 is to moniter that the cat is working so ether the cats not working or the secondary 02 is giving incorrect readings
  3. May 23, 2012 at 5:19 PM
    prerunnerSD
    Northeast USA
    so do you recommend i get the secondary 02 sensor replaced and see from there?? would both cats be bad or just one?
  4. May 23, 2012 at 5:23 PM
    0psi
    0psi Well-Known Member
    Tommy
    Westminster/glen burnie Maryland
    Color match handles,sport hood,fx-r retrofit,fog light any time,eclipse avn726e
    P0420 is most likely a bad cat not a oxygen sensor.you need to check the down stream o2 on a scan tool maybe you will get lucky and its bad but i Doubt it.
  5. May 23, 2012 at 5:26 PM
    trdsteptaco
    trdsteptaco Member
    jeremy
    mass
    02 taco trd step
    you can try it but i don't like to throw parts at things. do you still have the original cat in it
  6. May 23, 2012 at 5:26 PM
    prerunnerSD
    Northeast USA
    so which cat should i replace. there are two you know... people are never clear on this from what ive seen
  7. May 23, 2012 at 5:31 PM
    trdsteptaco
    trdsteptaco Member
    jeremy
    mass
    02 taco trd step
    i hate to say it but he's right. that is the only way of knowing and it can be a cheap scan tool it needs to be somthing that data logs quick and of course you need to know what to look for
  8. May 23, 2012 at 5:34 PM
    prerunnerSD
    Northeast USA
    no i tossed the original sensor...
    when you say replace the cat could you please define your terms. this tacoma has two cats.. front and back so not sure which would is recommended to fix with this code.
    thinking of calling the dealer at this point.
  9. May 23, 2012 at 5:39 PM
    trdsteptaco
    trdsteptaco Member
    jeremy
    mass
    02 taco trd step
    now im confused are you sure my 02 3.4 only has one its between the primary 02 and secondary 02
  10. May 23, 2012 at 5:39 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    If you were closer I could probably help you install the new one. It's easy todo your self get the o2 specific socket and then spray the sensor threads with pb blaster great penetrating lube leave it to soak for a min and attempt taking it off
  11. May 23, 2012 at 5:41 PM
    trdsteptaco
    trdsteptaco Member
    jeremy
    mass
    02 taco trd step
    the only cat that can set that code is right before "closer th the engine" the secondary 02 sensor idk maby some have a post cat but if there's no 02 to check it the ecu has no idea is there
  12. May 23, 2012 at 5:44 PM
    prerunnerSD
    Northeast USA
    so it would be the 21sty cat the cat closet to the upstream sensor not the main rear cat right?
    speaking of cats.. meow girl
  13. May 23, 2012 at 5:48 PM
    0psi
    Tommy
    Im pretty sure california emissions trucks have two cats.one in the down pipe where they come together and one farther down.
  14. May 23, 2012 at 5:54 PM
    trdsteptaco
    trdsteptaco Member
    jeremy
    mass
    02 taco trd step
    its not so much the primary 02 that we care about for this its the secondary thats important to identify the correct cat it will be the cat in front of the 2nd 02 sensor normaly, in this case it's different because both cats are between the primary and secondary 02 sensors. one of the techs i work with came from toyota I'll get a answer from him
  15. May 23, 2012 at 5:56 PM
    trdsteptaco
    trdsteptaco Member
    jeremy
    mass
    02 taco trd step
    that wouldn't suprise me its not unusual i just haven't seen one on the east coast
  16. May 23, 2012 at 6:01 PM
    prerunnerSD
    Northeast USA
    so what is my next course of action... i dont mind doing all this stuff myself.. its fun actually.. should i just replace the other sensor and go from there or replace the 21st cat towards the engine... any experts feel free to call me if u have time to explain the situation 619-630-8251 im jonathan
  17. May 23, 2012 at 6:03 PM
    0psi
    Tommy
    massachusetts used cali emissions 2002 so thats could be why it ended up on the east coast.
  18. May 23, 2012 at 6:09 PM
    0psi
    Tommy
    When i put the 3.4 in my 92 4runner i used a o2 simulator i have a cat but the sim was cheaper the the sensor.6 years and no code.just a thought
  19. May 23, 2012 at 6:20 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :( I have been reading about your trouble and I offer this to help. You may want to look at your catalytic converter while it is cold. Look to see if the outer casing is discolored and looks overheated. Look for dents or holes in the casing. Take a rubber mallet or your palm of your hand and strike the converter and see if it rattles, the inner converter material could be broke up inside the casing. If none of that pans out, you may need to remove the converter and look at it to see if it melted in the inside. Good Luck.
  20. May 24, 2012 at 5:01 AM
    trdsteptaco
    trdsteptaco Member
    jeremy
    mass
    02 taco trd step
    i just talked to the ex toyota tech i work with he said its the front cat you just need to make sure the rear cat isn't melted at all by looking through it. this makes cents being i front that one will be doing most the work
