Replaced Wheel Bearing to No Effect
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hightidesmoothride, Nov 25, 2024.
  1. Nov 25, 2024 at 8:45 AM
    hightidesmoothride
    hightidesmoothride [OP] Member
    2006 4x4 Access Cab, 70,000 mi and no modifications. Just replaced the passenger side wheel bearing yesterday, as all indicators were pointing to a problem there (play in wheel, hum that went away when turning right). However, still have the exact same vibration that I can feel through the pedals and floor board, especially at about 35 mph.
    What would be a recommended next step? Tire rotation/balancing? Greasing U-joints?
  2. Nov 25, 2024 at 9:55 AM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Try rotating tires and see if the problem follows the tire.
    What kinda tires are you running? Are the treads chopped up/unevenly worn? any play in the CV shafts? axle nuts properly torqued?
    Do you grease the U-joints regularly? If not and they're dry, then greasing them after you start getting vibrations is likely too late, as the damage has already started.
    Could also be the needle bearing on the front diff. Does the problem go away in 4wd? Could be a good time to replace that bearing with the ECGS bushing before self-destructs and takes out the front diff.
    B52BigLou likes this.
  3. Nov 25, 2024 at 2:21 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
  4. Nov 25, 2024 at 2:44 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I'd do the tire swap first. Might check your driveshaft carrier bearing -- the rubber part might be toast.
  5. Nov 25, 2024 at 3:02 PM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    If you turn right and the noise goes away, IME it's the front LH bearing that's bad. YMMV, but this has held true for me.
    But maybe you have a tire problem as said.
    Logger and HWI like this.
  6. Nov 25, 2024 at 3:19 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yeah, I'm betting it's the opposite bearing as well.
  7. Nov 25, 2024 at 5:06 PM
    hightidesmoothride
    Thanks for all of the advice. Fighting daylight post-work this week but hopefully can check a few of these tomorrow and can share some findings.
  8. Nov 25, 2024 at 9:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes. That is true.
    Turning right places MORE load on the left wheel.
    And LESS load on the right wheel.
    Less load = Less noise.
  9. Nov 26, 2024 at 4:02 PM
    hightidesmoothride
    So, no change whatsoever after doing all of the following: rotating tires, greasing and checking u-joints (no play), checked CV shafts (no play), checked carrier bearing (looks solid). Assuming the most logical next step would be to replace the driver side wheel hub?
    koditten likes this.
  10. Nov 26, 2024 at 4:07 PM
    TacoTuesday1
    FL
    bearings are usually replaced in pairs.
    you could check the balance and condition of your propshaft as well as measure free spin and roadforce balance values on the tires, check for out of round or bend, etc
    ridefreak and fatfurious2 like this.
  11. Nov 26, 2024 at 5:15 PM
    koditten
    Kirk
    Central Michigan
    Take the brakes off, install tire, rotate tire while using a long screwdriver as a stethoscope. Have the screwdriver tip near the bearing housing and the handle in your ear. If bad, you will hear a very gravelly sound.
  12. Nov 27, 2024 at 5:53 AM
    hightidesmoothride
    Was under the truck again and noticed the heat shield on the drivers side catalytic converter has completely fallen off. Could this be at all related to the vibrations/having a negative effect? I had hose clamped it down a couple years ago but I guess it just completely rusted through even the clamp at this point.
  13. Nov 27, 2024 at 6:00 AM
    Derk33
    Derk33 Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    I believe the front needle bearing is most felt around 35mph, easy way to rule that out is put your truck in 4hi when you feel the vibration most and see if it goes away. If the vibe goes away in 4hi the it’s the needle bearing making the vibration.
  14. Nov 27, 2024 at 6:13 AM
    hightidesmoothride
    There was no noticeable difference when driving in 4hi, vibration seemed exactly the same
  15. Nov 27, 2024 at 9:16 PM
    Project510
    Project510 Well-Known Member
    James
    Fremont, Ca
    OP - I hope you dont mind me piggybacking off your thread. I was having a very similar issue to yours. Ive read countless threads on different vibrations and the many causes.. and I was not seeing anything that it could be until I got to this post here:
    Got under the truck and wiggled the axle and wouldn't you know it.. pretty sure that's my problem. So I hopped in the truck brought it up to 35 mph vibration started so I flicked it into 4Hi and smooth as stock. FCUK.
    All the reading I did before I bought this truck, never heard of the needle bearing or ECGS. Not a single vibration on my test drive, or any time I was in the truck before. I mean I bought it from my Brother in-law. My niece and nephew and my own son have been in the truck. Nothing. So yea. Thanks @Derk33 pretty sure you solved my issue.
  16. Nov 27, 2024 at 9:22 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Change the left bearing.
  17. Nov 27, 2024 at 9:52 PM
    picturethis
    picturethis Well-Known Member
    Billy
    Issaquah, Wa
    2001 and 2016 Silver Tacoma DCLB TRD Sport
    BAMF Grille CBI Sliders Victory4x4 roof rack Cali Raised fog lights FNFX wheels Falken Wildpeaks tires
    For me, after getting a front wheel bearing fixed, still had issues, also a bad rear wheel bearing!! Fixed
  18. Nov 27, 2024 at 10:18 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    My 05 had all signs of bad wheel bearing on one side, replaced it, no change, moved new bearing to other side fixed it. Other side did go bad not much later too.
    Even had 2 shops tell me wheel bearings were fine before I did it myself anyway.
    Wheel bearing may not be your issue, but if you only did one side, try doing other side.
  19. Nov 28, 2024 at 8:02 AM
    TacoTuesday1
    FL
    should have an ECGS bearing.
  20. Nov 28, 2024 at 8:08 AM
    BLtheP
    Plano, TX
    An ECGS bushing isn’t going to do anything for a noise when turning in one direction.
